Thanks @peterfermtech .
CTL Well-Known Member Oct 31, 2019 #22 Lovey said: Just another question if I may please? I initially put that I was going to use a 60A breaker in the engine bay, however now I'm not so sure. Would a 50A at each of the above locations be a better size, or some other combination? Click to expand... Your fuse should be matched to lowest rated item in your circuit. In your case the Anderson plug which is 50amps.
Drewswb Well-Known Member Oct 31, 2019 #23 If your going colours Blue =Cold ,Yellow = Sun ,Red = Battery always hot I dont know why its so
Lovey Active Member Mar 26, 2020 #24 G'day all, I finally got around to installing the power outlets in the tub, took a while though . The mounting spot for the home made bracket. Thanks for everyones help and suggestions, I really appreciate it. Thanks for looking, Steve
