using too much coolant
gothe100
hello fellas
looks like i have a big problem with the old girl. its using to much coolant, i used 1.5lt of coolant in two days (80kms). its not dropping any on the ground so that rules that out, the exhaust fumes are smelly like coolant and can burn your nose hairs if you get to close. so can anyone tell me where the coolant is going to or from? other than straight out the exhaust pipe.
CHEERS craig
gothe100
i checked the fluid level and theres no milky looking coolant, havent checked the oil yet but the last week i checked and thats the same
MawsonSnow
it is fairly common.
The gasket is compromised between the combustion chamber and a water jacket.
At idle the gasket seals enough to keep the cylinder compression from blowing through the bad spot.
When the car is under a load (driving) the combustion heat and pressure rise, the cylinder compression then exits the combustion chamber and enters the water jacket.
And then it will come out the exhaust..
Any white smoke?
4runnerSteve
Try filling the radiator overflow bottle, then drive it for a bit, probably about half an hour or more. When you stop, kill the engine and straight away check the radiator overflow bottle. If the coolant in the bottle is boiling then its almost defiantly the head gasket.
My 4Runner did exactly that soon after i bought it. Twice.
muc the truck
i checked the fluid level and there's no milky looking coolant, haven't checked the oil yet but the last week I checked and that's the same
About 1 in a 100 cars end up with milky oil and oil mixed with coolant when they do a head gasket . 99% of the time as a result of piss poor coolant service history the head gasket rusts and permits combustion gases to enter the cooling system and coolant to enter the combustion system when its not running . at the beginning little losses in performance and coolant are experienced but it gets much worse . You need a leak down test done on the engine coolant system and a compression test . now is he time to park your car until such time you can fix it and if its a long time drain all the coolant out of it otherwise it will end up leaking in the cylinder , past the rings and can lead to rusted pistons stuck to the bores .
gothe100
thanks mate i will try that and see what happens
wardss
does your truck have the same dodgy egr cooler setup like early bt50 and pj/pk ranger because they apparently corrode and leak coolant straight into exhaust system???
