Using Hema Maps with an IPAD in remote locations.
peter1
Hi all
Your advice please - I am considering purchasing the Hema Maps to use offline on an IPad. ( Ipad Air with Wi-Fi & Cellular). I have been told that the IPad GPS uses mobile phone towers to locate your position. Therefore, the Ipad GPS cannot be used in remote locations.
Does anyone have another way of locating your position so that the Hema Maps can be used without GPS connection.
I would like to be able to mark my current location so that I can track my trip on the Hema Maps.
Regards
Peter
If you have the iPad that can take a SIM card it works perfectly fine without phone reception or a sim card.
They have a GPS built in and operate the same as any other GPS unit
I run Hema on a Ipad one and a iPad Air and an iPhone and very happy with it and it's accuracy
I have been to Cape York, Simpson Desert and Vic High country with it a number of times amounts many other trips
Tink
Hi all
Regards
Peter
You have been told wrong info.
Apple combine their GPS chip with their cellular chip. Not sure why but Apple often do things differently. Anyway what this means is that you need the cellular iPad if you want GPS functionality. Nothing whatsoever to do with mobile phone towers. So if you have a cellular iPad, you have GPS and Hema 4x4 Maps will work anywhere. I have used Hema 4x4 Maps for 12 months in many remote locations, for example we crossed the Simpson Desert, and have never had an issue with the GPS, the iPad or the Hema maps.
Where some confusion may be coming from is that Apple maps and Google maps use the known location of wifi hotspots and mobile phone towers to "assist" GPS accuracy in the absence of a signal from GPS satellites. This is normally only a problem in city centres where buildings may bloke satellite signals.
Tink
monbeg
Yes, I can vouch for that, I was out of phone range for about a week in SW Queensland etc and apart from iPad charging issues it all worked perfectly when nothing else worked.
I agree. Your iPad must have 3G capabilities. It does not need a SIM card and costs nothing. I pair my iPad to my iPhone if I want to use the Internet when in mobile service so a sim in the iPad is pointless.
The iPad with 3G will run your Hema anywhere in Australia as long as you can see the sky. FREE.
oddsmux
One way to get around the lack of GPS on the WiFi models is to buy a GPS Bluetooth receiver. Advantage is that sometimes you get a better signal as you have separated the GPS antenna from the device. Disadvantage is that it can cost around the same as the cellular version. I can concur that as long as you have maps installed locally the you do not need a data plan in order to use the cellular iPad.
oddsmux
Off topic - Another option of course is to buy an Android tablet that has the GPS chip in a WiFi only model (many like the Nexus 7 do they just take a little longer to get a GPS lock in remote areas)
Tink
Hema 4x4 Maps only work on Apple. You would need another mapping solution for an Android device.
Tink
Tink
TonyF8
I'm running hema maps, not explorer through memory maps on a samsung note 10.1 and do not have any problems.
Gavo
Still wrong. Suggest you check your facts before correcting somebody. :D
Hema 4WD Maps is only available for Apple devices. Hema Explorer, a very different mapping application, is available for both Apple and Android devices.
Have a look here for a comparison of products
Hema - Hema app comparison
Tink
Fair call, can't actually work out what advantage of the 4wd is vs the explorer.
Pretty expensive app all the same. I'm a huge fan of adrozic, but that's presuming you have maps.
Superdad
The only issue i have found is that if you are outside of internet connection, you cannot download the actual map. I just make sure i zoom in nice n close on all the areas i might be going before i get out of range. That seems to store the map itself in the IPad's memory.
Do you have the full blown Hema 4wd app or the cheaper one? All of the Hema maps are stored on the ipad hardrive and I have no issue accessing any of them, I don't even have a sim card in mine.
Superdad
Full blown one. Should have been clearer - it is the 25k maps that need to be downloaded not that standard ones
But aren't they still all stored on the ipad?
When you go into more maps, it asks you if you want to display all maps on this device and it populates the screen when you press it.
Or am I misunderstanding you?
Superdad
I would love to be schooled but if i put my IPad into airplane mode, drop into a 25k map and move to somewhere I have not viewed, then it just leaves blank gridlines so it appears the 25k maps are not stored in their entirety, on the device.
Donk94
Not all of australia is stored in all 3 lays with hema. An ipad or tablet would not have enough storage to hold it all. If you have an area that wont let you zoom you can download from hema whilst online. So you select the area you want and it will download all the info from that area. Its free to do, you can download as much as you want and you can do it all through your hema app
Gavo
That seems inconvenient as hell. Offline maps are designed to be offline.
Donk when I zoom in further on a location it automatically steps up to a more detailed map or I can manually select a different map
Are you saying there is even more info available than that?
