Unhappy Steering box.
80lover96gxl
105 cruiser ,,stearing box that bolts to chassis is unhappy and is leaking oil.
Is this an easy fix , ie replace a seal ? Or am I up for a new box ?
Any advice would be greatly appreciated.
Brian.
GUnka
Depends where it's leaking I guess. Rebuilt a couple of steering boxes many years ago now for old holdens back when kits were readily available but they were non power steering ones. If the leak is around the output shaft that holds the pitman arm am sure you should just be able to get the right lip seal to fix the leak so long as the shaft isn't to badly grooved. If the leak involves the power steering side of things it may just be a loose fitting or an o-ring on one of the lines that has just gone hard and lost its ability to seal when under compression. Maybe look into seeing if someone does a rebuild kit for it and give it a good birthday. Am sure a decent manual will guide you through the process.
GUnka
Cool, the only pain you will have is probably pulling the pitman arm off to get to it then. You may be able to pick a puller up from supercrap or somewhere, if not prob have something in the shed that will do the job or can get a puller kit from work as they can be a right ba$tard to get off if haven't ever been removed before. Hopefully is just the seal that has gone hard and the shaft itself isn't scored too much so just a new seal will do the job. Give us a shout if you want a hand or anything.
80lover96gxl
Yeah cool mate, cheers for the tip.
