UHF radio antenna mounts
MussoMan
Ladies and gentlemen,
Just a quick query reguarding mounting an antenna in a fiberglass canopy. Is this 1) advisable 2) possible. I have a glass mounted antenna already but this has the coverage of a polly pocket wash cloth (anyone with a young daughter will understand) and as I only have a nudge bar and a lovely wife that doesnt want to see the antenna every time she drives the car. I am open to any comments and helpful hints.
Please advise a novice.:)
Fox Shooter
Yep can be done but as the is no metal around the base for a good ground plane I advise to get a 'Independent Ground' antenna should be used. Just be aware of low branch's and car parks.
Nickj
Hey Musso-man
I nearly bought one of those (Musso ute) before I got my Pathfinder.
I think the antennas are called Gorund Independant as Fox Shooter said. They are quite common and should get one wherever radios are sold. You could always put it on the rear bumper. :)
My wife hates mine too, it's on the left side front bumper...
Nick
MussoMan
Thanks guys,
After spending some time at the local Opposite Lock store and talking to another ute owner and he showed me what he had done with a modified gutter mounted collapsible system so that the arial can be folded down when not in use. It was simple but brilliant.
Tats
How to Fit an Aerial
Driving from Sydney up to Riverwood Downs in the Barrington area some time back to a 4x4 Jamoboree, the traffic on the "freeway" (bloody stupid expression that) ground to a halt. We saw a bloke in front in an old Tojo ute whom we recognised and watched as he turned off on a side road. We thought we'd follow. As we drove around the exiting clover leaf, there was the silly coot bogged in the centre, he'd decided to take a further short cut. We rescued him, but before we got going on, he asked for a hand to fit his CB. We agreed, and watched in wonder at his workmanship. The set was attached to the door pillar behind the driver's head with an occy strap, and plugged into the cabin light. But where to put the aerial? Without further ado he resolutely pulled out a bricky's hammer and cold chisel and punched a ragged hole through the cabin roof and pushed the aerial through, tying it in place with a piece of wire. "She'll be ok," he said, and remarkably it worked. (Should have thought of that when fitting the little Uniden in the Jeep, eh!).:rolleyes:
Tats:cool:
