UHF issues
skot
Just wondering if anyone has had a similar problem to what im having with my uhf radio. My uhf works fine when i first start my car and works as it should for about half an hour, then after that all i seem to get is static when people try to talk to me and they cant here me at all when i try to talk back. I recently converted my ipf driving lights to HID and it does get interference when ive got my high beam and spotties turned on, but none when there turned off (atleast i dont think so anyway) but i cant figure out why it works fine when i first turn the radio on but slowly gets worse and worse until it seems to not work at all. Antenna is new although it is only a cheap axis one. I might try taking my spotties off and see if it is any better, but i wouldnt think it would have got interference with the lights turned off and no power being supplied to them. Any help would be very muchly appreciated.
Scott
Yota
Scott
Scott, it could be a heat issue as some radio's have a thermal overload protection built in. What brand of radio and what type of antenna are you using. First thing I would check would be the antenna system, if you know a friendly ham with an swr meter that covers 477mhz that would be a good place to start. Often high swr will cause a radio's transmit to shut down after a few minutes use. Preferably u want swr under 1.5 to 1 but lower is always better. If the problem is not the antenna then it will be a trip off to the radio doctor.
Regarding your HID lights ferrite chokes placed around the wiring to the HID lights may solve the interference issue.
skot
The antenna is only a cheapo axis one so i dont expect much out of it, it just seems since i converted the driving lights to hid ive had the issue. but the fault is still there when the lights are turned off. Radio is uniden, that i know worked fine before i installed it. I will swr it in and have a look as the boys have a swr meter at work, its just when its working it swr's up fine like theres no problem at all.
Yota
Radio problem
Scott, see if you can borrow another antenna preferably using another feed line too, this will tell you if the problem is radio or antenna related. If antenna it is an easy fix but if it turns out its the radio a trip to a tech will be required.
Interference from HID is not uncommon especially with the cheap Chinese HID kits.
Cheaper radio's also seem more likely to pick up interference created by the vehicle itself too. clamp on Ferrite should be available from most electronic suppliers, Jaycar etc and they would be my first attempt at a home fix.
Axis
Hi Scott,
Did you end up getting a fix for this? I get static interference on my UHF but it is intermittent. I feel it is worse in built up areas. No additional devices added when it started, and when it occurs it is on all channels.
Still occurs when I have removed all accessories (in car chargers, OBDII dongle). Have put on some spotties but it was occurring prior to this. I do have a bit of spare antenna cable under the dash (cable ties in figure of 8) so not sure if I should be cutting this shorter.
Any tests I can do without having access to a 2nd antenna? Hard to pinpoint as it is intermittent. Radio is an Oricom UHF088 with Benelec antenna wired direct to battery +ve and -ve.
Cheers,
James
The antenna is only a cheapo axis one so i dont expect much out of it, .
Hi Skot
Without being rude I think you to change your way of thinking a little mate ;), UHF requires all components (radio,cable,aerial) to be working correctly to have any chance to make a nice clean transmission..
Why stuff around with sub par ,radios, crappy cable,cheap aerials.. In your case it's an aerial, throw it to the shitter and buy yourself a decent RFI etc...See when the aerial and cable are sub standard who cops it next while transmitting the radio :eek:...
You may need it one day in an emergency and you at least want it to transmit properly..
Goodluck , hope you get it sorted...
