UHF antennas/ aerials
snowboardin93
hi, at the moment i am currently using a gme 4.5db, 60cm uhf antenna, i cant really pick up that much with it i have it on a gutter mount, and am unsure as to weather my aerial is not much good or possibly my radio the radio is a gme tx472s which i would say has got to be at least 17 years old, would i be able to pick up/receive more if i were to upgrade to a 6db antenna?, any ideas?
cheers:)
Bainsy
nah you should transmit and receive fine with even a 3dB, maybe your transmitter is getting old or perhaps the antenna needs to be earthed? did you buy it as a kit or did u solder it all together yourself? have you got a pic of your setup?
another thing to think about is how are you testing it? the other radio you are trying to talk to may be the one thats not working properly. once you have sorted it out, you will be very happy with the 4.5dB.
snowboardin93
hi here are some pictures of the setup i have, dont know if they will help?, i dont think that the aerial is earthed, and it was all soldered by my pop, i might have to try and have it earthed
thanks for the help:D
in the manual specs it says rf output power is 5watts RMS @ 13.8 volts
is this right?
is your radio running at 5watts or at 1 watt ????????,i would imagine you can change it,the manual should state how,5Watts is obviously better.If its 1 watt then that would explain poorer coverage other than aerial issues...
snowboardin93
i have looked in the manual and it does not say anything about changing the wattage, does this mean it cant be changed?, or would you know how to change or check what wattage it is?
thanks again
thanks again
mate hav you a link that i can download the exact same manual,or a place where i can get it....
snowboardin93
hi i could email it to you if you like?, but if you want to download yourself you can See if you can open the file on this site... gme tx472s is down the list
mods.dk – manuals
this is where i downloaded from though you will need to make an account, that takes around 5 mins to do
thank you so much for all of your help:)
