Ta mate, bought a cheapy on ebay for half the cost of store price
Be careful with those cheapies... U might find that they will only let u lower your tyre pressure down to around 20psi, anything lower will send off the alarm. U need to look at the specs first.... unless u don't plan to use them in that way
Mainly curious here... but for those that run internal Sensors, what happens when u rotate your tyres? Can u adjust the readout to read the correct tyre pressure for the correct tyre position?? (if u know what I mean)I know the internal ones give better temperature sensing, but that is a lagging indicator of low pressure so not as useful as it sounds.
Also when changing tyres on rims you need a fitter with 2 more brain cells than most.
I have internal ones on my Jeep, but with the caravan I went with cheap eBay external ones (six sensors) and they were very unreliable.
I have now purchased the ODB2 brand with six wheels, fantastic product, and I turn the caravan pair off when not towing.
and they are priced at $78 - $125, which is very reasonable
Car & 4WD Solar Tyre Pressure Monitoring System - TPMS
Install in under 10 minutes Turns off and on with vibration/movement Includes solar dash unit and four wheel sensors IP67 Waterproof External Wheel Sensors Comes with 4 spare batteries* Range up to 8m so perfect for long distances. (Longer need repeater) Improve your fuel economy with...obd2australia.com.au
Just checked out their TPMS on their website but they do not mention the "available" Pressure RANGE (ie: minimum)... They mention up to 55psi but don't mention the minimum...
Any idea as to what this may be?
I looked at theirs also as their price is very competitive. But like you I couldn’t find a minimum pressure and ended up with Safety Dave which I am very happy with. Had a set of Digioptions which appears exactly the same as Safety Dave, however the Safety Dave monitor appears to have a better battery, only need to charge every week or moreJust checked out their TPMS on their website but they do not mention the "available" Pressure RANGE (ie: minimum)... They mention up to 55psi but don't mention the minimum...
The GMC has integrated TPMS using internal sensors as standard, as it is a vehicle standards requirement in the States.Mainly curious here... but for those that run internal Sensors, what happens when u rotate your tyres? Can u adjust the readout to read the correct tyre pressure for the correct tyre position?? (if u know what I mean)
