Tyre deflator
red hilux
I found this tyre deflator on ebay, and I won the bidding for 22 bucks
http://www.ebay.com.au/itm/BOGBUSTE...67?pt=LH_DefaultDomain_15&hash=item4aea2d383f
Man, this is an awesome deflator. As your dropping your tyres down, it displays the pressure your at while deflating. Its accurate while deflating to 1 psi on my 31's.
If I want to go to 12 psi, I can keep deflating until 11 psi, push that what ya ma call it back in and the pressure rests at 12 exact. Ive confirmed this with another gauge
Hmmm, handy not having to flick the regular slide of to get accurate reading as it's deflating, but then I now know to count a second for a psi to drop.
Have found that works great and gets me within a psi or two to finish off with quick second slide operation.
Overall, I think I would rather have the plain old gauge one myself, too likely batteries will one day go on you at a bad time, or electronics might go if it gets damp etc.
Look after it in the glovebox and you will likely be ok for a good while.
I have had a set of staun deflatetors for many years and can't fault them.
Lol, don't start that one here !! :D
Just go have a read at this ExplorOz thread from a week or so ago . . . Tyre deflators - Recommendations ?
Having had both Stauns and other types like Ezy, as many have had, I am sure for serious offroading where multiple pressures are needed, then Ezy style deflators are the way to go.
Unless you want to carry 3 sets of Stauns, and then you will still need to check pressures and adjust down a few more psi if needed.
ULost2
thank for link and the chuckle at this reply
I have two pairs of Staun Tyre Deflators, which I have had for some 10 years.
One set is set for 28psi and the other for 18psi.
I placed a drop of red paint on one set to identify the lower settings I use for sand driving.
The higher set pressure (28psi) is for normal off road driving.
With four of them, you progressively screw one on to each wheel and pull the centre pin.
By the time I have gone around the car, the first has reached its set pressure.
All very simple and practical.
I thought people went bush to slow down a bit ::rolleyes: :confused:
Now wasn't there a thread about over loading the ute recently :p
I will stick to the tyre T tool if I'm really in trouble. Just need to remember the get to compressor out of the shed.....and buy a generator to use it out bush lol
abw
I have a set of 4 Trailhead tyre deflators which are similar to the Stauns. I have 2 set to one pressure and 2 to another. I find them really easy to use..just screw them onto the the valve and wait until they stop (2 one side) and switch to the other side. I just double check the pressure from time to time, to make sure they are correctly calibrated.
Not a huge fan of the ARB ones where you have to unscrew the valve. The threads on the tyre valves are so tiny I'm afraid I'd end up stripping a thread (particularly for someone with all thumbs:D). And where does that leave you? I had a cheap knock-off a couple of years back. But after switching to the auto tyre deflator, I haven't looked back. Though, if I had my choice, I'd stick with the genuine Stauns...they look well manufactured.
I also have one of those Bushranger 3 in one gauge/deflators for "custom" tyre pressures.
MUX STX
My 4 stauns are set at two different pressures, 20psi for sand driving and 18psi when we had the camper trailer on the back while on the beach.
Two are marked with black paint, they are the 18psi ones.
Simple to use and I really like them.
GaryM
As above, I have the stupid guage with its slide piece to check pressure. but ill be getting a kit of 4 Stauns. a pair marked for one pressure and the other pair for another as a few have said above. I need to preserve my back for shoveling.
Just wait until you lose a bit of confidence in the Stauns, you will be back to an Ezy tpye unit in no time.
After a year or so, Staun type get kinda sticky, can't trust them to air down to within that 1psi, so you have to go around and adjust, needle gauge them, etc.
PITA.
Having 2 pair at different levels defeats the purpose of them, which is, to walk around the vehicle screwing them on (all 4 of them), then by that time your first one is done, and you walk around the vehicle again unscrewing them.
Doing 2 x 2 would be a bit of a wait.
I know it's not a race, but you do want to get it done and get driving again.
There really are pros and cons with both types, the Stauns are a great concept, but after a while (6 months) I sort of saw through the issues, and frankly the time squatting to EZY one tyre down is nix . . . it's done right there and then, to whatever pressure you want, and you do want more than 1 or 2 common settings for 4WDn in different conditions / terrain.
cookie64
Yep I'm with you, never had any issues with them, had them for about 10 years, I try to recalibrate / check them before each trip to 22 psi, allows me to drop further if needed without risking my sidewalls or rolling tyres off rims
cheers
phs
22psi :confused: is that dropping back to HwY pressures? Lol
I'm keen to get there low series
They come preset to 7psi that's perfect
cookie64
I normally run 40 in mine so 22 gets me everywhere so far, Robe, Simpson, Canning but having had my fair share of tyre damage in my early 4wding years, I am a little more protective of sidewalls to the detriment of tread sometimes
cheers
