Tyre deflaters advice
Frug
Hi there everyone.
I've heard that you can buy tyre deflaters that are set to certain PSIs.
Anyone heard of this? If so, what brands and experience have people got or used?
I've seen manual tyre deflaters, like the ARB ones, with a gauge and it removes the valve core.
Any suggestions would be really grand!!
Doug
poiderav4
tyre deflaters
I have several mates at work that use them and swear by them, I saw them in Rays outdoors for $85 a set of 4.
I don't use them myself, an instructor from the 4x4 course I took told me to go from 32psi to 20 psi it takes 35 seconds of releasing air and it works for me.
Peter
cloughcarib
The most common of the preset ones are the Stauns. I use an ARB EZ Deflator as I set my tyres at different pressures depending on what I'm doing
mac_man_luke
I use a Currie deflator (identical to the ARB)
Its great, really quick and allows me to vary pressure according to conditions unlike stauns.
xtrailer
Iv'e got the staun, brass ones (set of 4). To overcome the pressure adjustment i decided to set 2 of them at 30 psi and the other 2 at 22 psi and colour code them. That way i can at least choose between 2 pressures and adjust manually with pressure guage later on if required.
mick94surf
Cant beat the ezy deflater for speed, ease and accuracy. Cant let air out any quicker than by removing the valve core, oh and still having it hold air again lol
Cheers Mick
Westys Acc
Hi there everyone.
Doug
G-day mate. Quick question. Why do you want a pre-set deflators? Imo a ezy deflator such as the arb or ironman are a better option as they allow any pressure to be set.
You don't always use the same pressures in all situations.
So yea, just a thought.
Kallen Westbrook
Owner of
Westy's Accessories
mccpijs4
When on long touring trips when the tyre pressure needs to go up fir highway and back down for rugged tracks, you can put all four of the brass deflators on and do all four wheels at once. I've not used the one where you can take out the core, if it's much faster then maybe you can do four wheels just as quick. Now just need four compressors....
mccpijs4
(I meant to say when your having to put the pressure up and down *many times* over a long trip)
Westys Acc
Yes I see you point. The ezy deflators are quick. Is say 5mins once in a routine to do all 4.
As for the compressor, a good engine bay mounted arb or of sorts will have you sorted in no time.
Kallen Westbrook
Owner of
Westy's Accessories
PJR NSW
Banned
We use the Staun deflator set.
The four are set as follows:
One set to 20 and another to 26 for general off road use,
one set to 15, and
one set to 12 for sand and the more rocky and muddy work.
The main reason I like them is that you can put them on, forget them and stand up. Blood circulation in my legs isn't the best these days.
The ones used the most are the 20 and 25 psi ones for general doirt work. We use 20 front and 26 rear. We have only gone to 15 once for a part of the Simpson WAA line.
Just as heaps of different people recommend for the larger Patrol and Cruise cars. It works for us.
Phil
Frug
Thanks for all the info guys!!
Can anyone recommend and good deflators with the dial gauge attached? I've seen the ARB one, just wondering if there's anything else out there that's worth looking at. Seems that anything with ARB on it is about 30-40% more expensive. Do you really get what you pay for with ARB product?
Also, any recommendations for a good small hand held electric tyre inflator? Just one that uses the car's battery.
Doug
G'day Frug, I think you've made a good choice . . . the deflator type where it removes the valve is better for many folk.
I have Stauns, but find I use so many different pressures, it's just too difficult to use them.
Mostly I use them to get down to 22, then air down manually with digital pressure gauge 'nipple' on the bottom of the handle if further is required.
Stauns are great if it is just one pressure all round needed every time, by the time you fit the last one and go back to the first, it's usually done . . . tried having 2 set 22, and 2 set say 17 for sand, colour coded them, but it defeats the purpose !
Example, just back from Beachport to 28 Mile Crossing down the SE . . . we'd air down to 18, then moved to 14, and 12 progressively as we struck softer beaches.
I find the digital pressure gauge more than fine for dropping a couple of points each tyre on the fly, only 3 or 4 seconds each to do this.
Westys Acc
Doug
Comparing my in-laws arb deflator to my ironman which was half price, the only difference is the mech. Mine has a bit more slop than the arb.
Still does the job, but it may not last as long.
I've seen a cheaper Chinese brand mentioned above, but I doubt you'll get customer service.
So again, stick with trusted brands and enjoy your time outdoors
Kallen Westbrook
Owner of
Westy's Accessories
prawns
.....We use the Staun deflator set.
The main reason I like them is that you can put them on, forget them and stand up. Blood circulation in my legs isn't the best these days......
Phil
I hope your not putting them on, then forgetting about them and going driving with them installed.
Else your tyres will slowly lose more and more and more pressure as you drive (go over a bump, it increases the pressure in the tyre - the Staun lets some out...rinse and repeat and repeat and repeat)
Dont drive round with them on :D
poiderav4
deflated
I use the nipple on the back of my trye gauge to let air out for 30 secs then check with gauge four tyres takes 5 mins, less if the wife removes and replaces caps as i go and reinflation is with a stand alone tjm compressor that plugs onto the battery with alligator clips and takes around 45 secs for each tyre.
Peter
phs
I own stauns and an ARB E-Z most on the time I use the stauns much quicker and easier . the other day I used the e-z cause I recently got a new set on tyres and the bead would not have dried so I only dropped them to 24 psi . the drama is the ARB gauge is so out of whach it's a joke 15 psi on the gauge is 24 ? Fairly average that's a huge difference .
frosty
I'm quite surprised at that. Mines a couple of PSI out. I would have thought ARB quality control would have caught that. I'de take it back.
I hate the stauns. Mine would'nt stay at adjust. After a few uses, I'de have 4 different pressures ranging 10 Psi. Plus, I always have different pressures.
PJR NSW
Banned
My stauns did the same and lost the setting. That is until I got serious about tightning them. Not a change in over 18 months now.
I wonder what all the rush is about anyway. Whats wrong with a rest for a few minutes? At the worst case with the Stauns for us is one tyre at a time at with only one set at 12 and one at 15. Normally two at a time (20/26) with time to make a cuppa and drink it on the run. It's not as if we are going to miss the sunset or something.
Phil
03GV
You can get $20 knock off ezi deflator's off ebay, mines going strong after alot of uses.
Brass components with vair guage, good quality. I go out wheeling with someone who uses stauns. He's a pain in the ass, takes to long and everyone has to wait!
Anyone who says stauns are quicker is dreaming, I got stauns over 10 years ago from 4wd action mag subscription.
They're not accurate and no good when your out and have to do alot of different tyre pressure variations.
They make good fishing weights though;)
