From memory another member here had one of the Russian variants, it may have been @dirvine in his little Chinese uteI'm in the same boat at the moment trying to buy a helical lsd for my hilux
I found those ones you listed similar in price to an original truetrac. I emailed them and they say they are identical to the truetrac (ie copied) so I would be more inclined to go the original.
I've been doing some digging and a couple of Russian companies make helical LSDs as well, but they have some sort of preload mechanism to supposedly help in zero load conditions like when a wheel is in the air. They also have more pinions than the truetrac so they should be stronger.
If the bastards would answer my emails I would buy one.
Interesting I've emailed these local guys again to see if their ones have any preload.
I'm pretty sure the Eaton hilux one doesn't have any.
Wavetrac's look great, I wish they made them for the hilux. I asked about a custom unit, 1200 USD each @ minimum 30 units.Look at wavetrack lsd to I had that in a previous car. Was stronger than the harrop true track as well which i blew up! But anyway id still just go locker.
