True story
IvanTheTerrible
Just spent a week trying to find a set of heavy duty standard height rear springs for out 2015 D-Max. The ute has a constant weight of about 2700 -2800 and with only 30000K's on the clock the original rear springs are shagged. Now I have rung all the big 4x4 suppliers and all the major spring manufacturers and basically been told the same thing. Not available. Lovell springs will make me a custom set but didn't really seem to enthusiastic about it but as it was my only option I decided to pursue it. Downside is I cant go directly to Lovell and they suggested I go through TJM as they are agents. So after trying some of the larger TJM dealers and again finding not alot of enthusiasm I rang the TJM dealer in Horsham in Western Victoria who not only was enthusiastic, he actually suggested something nobody else had. He will supply a set of TJM 450Kg rear springs that are 45mm lift and get their manufacturer (Carols Springs) to reset them to factory height. Not one other person suggested something so simple. :)
Ian
Jackolux
Mate just find your local , Spring Works take the Ute to them loaded , give them a look they will sort it , too easy .
IvanTheTerrible
Ta Da. Heavy duty standard height springs.
Ian
Jackolux
Dmax Springs you say , where did ya get them , why is the eye on one end rolled the opposite way , both my std springs and the GVM upgrade springs , have the eye rolled up both ends .
I would be asking that question before I went to the trouble of fitting them
maddon
carrolls are fantastic - a lot of the other spring guys get their springs done buy carrolls / my navara springs were rs at 200,000 klms and i got the back end rated to carry one tonne ; heap of extra springs etc and lifted 90 mm and specially lifted for the tool boxes on one side ; couldnt fit in my carport any more / then i had to lower the tray 40 mm / done another 50,000 klms since in some of the roughest tracks in stralya - been brilliant - drive in , in the morning and out in the arvo and hundreds cheaper than lovells etc
IvanTheTerrible
Reverse rolled to lower the spring. Nothing on this planet will open that eye up. Remember these are standard height, 450Kg GMV upgrade springs.
IvanTheTerrible
Not doing an upgrade. Just needed heavier springs as the vehicle sits close to standard GVM all the time. It is a work ute with tools 90% of the time and a touring ute with a canopy the rest. It is never empty. We Opted to go on the heavier side of what may have been needed as it's easier to take a leaf out of a spring pack than it is to put one in.
Ian
Jackolux
I get around with 1360kg front axle - 1390kg rear axle , it ride ok
when going away , we hook the Tvan up about 160kg on the ball and a bit of extra crap in the ute .
IvanTheTerrible
God I hope these settle down over the next few days or we will be removing a leaf or two. Current vehicle weight is 2750 and there is no movement in these springs when we lowered it of the jack. Currently 2 to 3 inches above what it was.
Ian
Jackolux
Yep ok , same weight as my Dmax , I'm happy with the way mine rides and handles ,
I have both eyes on top .
I have 500kg constant Tough Dog with Adjustable Shocks and there brilliant .0-9 setting with around 700% range.Glad I picked the adjustables
