troopy side windows
desert dog
does anybody know where to get `fly screens` to fit my rear sliding windows for a vdj78 have seen neat fitting ones but couldnt get brand to track them down
rogerazz
I just cut some screen wire to fit on outside and fixed with magnets when required. Carry them inside rolled up when not in use.
Did not know they made special ones that fit on? However I am ok with mine.
DX Cruiser
Bunnings fly screen mesh and 5mm black rubber work great and you can hardly see it there.
Marky07
G'day Roger, mind me asking what size tyres/rims you running on that troopy? cheers mate
rogerazz
G'day mate. I have 15 X 11.5 sunraysias with 32 inch Maxis Mudder tyres. Can't go bigger without a lift. Good in the wet and climbing off road but can get fairly noisy on bitumen as they wear.
Changed from Goodyear AT's 31 inch which I still have. Recently I made a bad move and swapped front tyres to rear. :eek: Now they are scalloping on the sides and so I have pumped them up to 50 P.S.I. to try and get them to run more on the center of treads.
Other thing to consider is age of tyres and if side walls can handle severe deflation without showing signs of cracking on inside of tyre walls :eek:
The longer you keep tyres the less flexible they become as the rubber gets harder and more brittle.
But hey, they do look tuff:D
Marky07
Thanks Roger, appreciate the tips. i'm currently running GoodYear LT 235/85 R16 or 32Inch but only 9.25inch wide in imperial standards and been thing of getting something which can handle the mud & sand a little better as I'm doing a road trip along West Coast and planning on beach camping a bit! Troopy doesn't have turbo unfortunately and have been told to be really careful about going too wide as it will slow her right down even more than she already is, not that I'm planning on dragging anyone! Any tips there mate? Cheers Mark
rogerazz
I could be wrong on my rim width. However I have heard and believe a wide tyre width is not necessary, because when deflated the footprint is bigger along the length of the tyre rather than the width. Logic tells me that AT would be ok in sand however maybe some of our members who do a lot of sand driving can give some good advice on correct tyres to use.
Cheers.
80lover96gxl
Hi Marky, most road legal off road tyres will be fine for sand driving but AT's will be a tad better than muddies.
In saying that I use fairly aggressive muddies on my trucks and have never had a problem driving the beaches here in SA, Particularly down the SE were they can be notoriously soft.
The key to successfully driving soft sandy beaches is tyre pressures and getting your tyres to bag out length and width ways .
Many say 18psi is a good pressure to run but many will also say that is still to firm for really soft sand. I like to start off around 14 psi then drop to 12psi and to 10psi if its getting really soft,, even gone to 8psi in some instances to avoid getting bogged on really bad sections.
The main idea is to get your tyres to float on top of the sand rather than trying to push thru it which will make your vehicle work harder increasing stress on components and will increase fuel consumption dramatically.
A good aggressive AT tyre like the Mickey Thompson p3 or cooper st maxx will preform well on sand and also give you good performance on most off rd terrains.
Before you head west find an area close to home and do a little experimenting with tyre pressures and see what best suits you truck, also load your truck to what you might expect to be carrying when your beach driving to help you work out pressures easier.
One more thing, avoid sharp turns at low pressures as its easy to roll a tyre off the rim or get sand in the bead causing a slow leak.
Rod1949
Can't go bigger without a lift :confused: On my stock standard 75 series I ran 33x12.5x15 without any issues.
Jessy
I had 33x13.5x15 Maxxis Mudders on mine during a West Coast Tassie trip with no issues at all clearance wise, stabiliser bars removed as well. Running 33x12.5 x15 Nankang Mudstars now, find them a great all round tyre for what I do and $215.00 a corner.
Jessy
I had 33x13.5x15 Maxxis Mudders ?? (Like a bar tread)on mine during a West Coast Tassie trip with no issues at all clearance wise, stabiliser bars removed as well. Running 33x12.5 x15 Nankang Mudstars now, find them a great all round tyre for what I do and $215.00 a corner.
Jessy
