Smeacs
Banned
Meet up with everyone and got out to Big Pats Creek By 11am to air down and say our hello's.
I lead the way followed by Rowen in his series 1 Disco, Then Bluebird68 in the shortie Patrol followed up by Michael in his Jackaroo. Grey Ghost was next in line with Big Matt playing Tail End Charlie for the day.
We Headed off up Mississippi Fire Line to give the novice 4wders a quick taste of what was to come. Got an oh god From Rowen at the steepest part up the top. All went well so it was off to Federal Short Cut for a look.
After hitting the bull bar of the Disco on a rock up this one the week before we took it easy as to not cause any more damage. Everyone got up the Entrance of this without any trouble so down the very tight track we went. All was going well till we got to the infamous bog hole with the before mentioned rock.
I picked the safe line that I was to take and headed in only to emerge from the other side with a 6 foot branch hanging out of the front on the car, I had awaken it from its watery sleeping hole.. It had managed to find its was up the the front cross member an conveniently picked a nice spot to rest itself between my gearbox and exhaust mount. After a lot of lying on the ground getting mud all over me I was able to cut most of the branch out leaving only about 6 inches still nicely wedged in its spot. A quick drive up to a nicer and drier spot and a bit more lying around it was removed.
From here we did a quick loop back around to Brahams Road then off on to Oat Patch Track. We made a quick stop at the top clearing for a photo or two then continued on back to Brahams for a short punt up to Patrol Road.
Crooked Creek Track was our next port of call. This one may have bee the favorite of the day.
Took a nice easy drive in for the first then we hit the Down hill section. Even with the recent rain the track was solid and the ruts where not too bad. At the bottom we had to negotiate our way past the washed out section of road, No issue to be had.
Continuing on to The B5 Fireline where we paused, thought about it, got told it was fine and turned right to head up.
Once again the track condition was good no slippage from any of the 4wds until 100 meters from the top where a wash away had become a home for some mud and made thing a bit interesting.
The Series 2 Disco, Being the first to find it, had no run up to work with but spun its way to some solid stuff allowing enough grip to crawl to the top. Having that in mind we got Bluebird68 to pass the Series 1 Disco (Which was running on roadies) so as to allow a helping hand if needed. Which turned out to be a good idea after about five failed attempts by the Disco 1. A quick snatch and pull and the path was cleared for the others, who did not want to under go the same defeat, all hitting the section with plenty of lead in their right foot. This made for a good show as they all pointed there rigs at a tree then the embankment then back up the track to safely make it to the top.
From the end of the B5 it was right out on to Brahams for another quick punt down to Lays Track to meet up with Stringybark Track. This track is mostly a straight down track which meets up with Lyrebird Road. Nice steep entry off a good right hand turn. This continues its downward path with a few ruts but nothing serious. Just as you are nearing the end, the track turns to a loose rocky slope. (The rocks where dumped a while back to allow greater access). This topped of the day to include a bit of everything.
All in all everyone had a fantastic day. The novice Drivers of the group got to try their rigs on a variety of different track surfaces and angles, and got a bit of mud where it should be. They also got to see how a snatch recovery works and a bit of bush mechanics well.
Thanks to all for what was a great day. And a big thanks to Bluebird68 and Grey Ghost for there help and patience with the less experienced.
Here are the few Photo's I got for the day.
Warby Day Out - 16-05-10 pictures by Smeacs - Photobucket
Look forward to seeing what everyone else got in the way of pics. I sure there is some good ones..
Look forward to heading out again soon with you all.
