Transfer Case - Output Shaft Bearing
oversite
Hi All,
I have recently noticed a knocking noise when driving, I think the bearing and/or seal in the back of the transfer case is gone.
The photos show a pretty clear problem.
I have never done any work on transfer boxes before and was wondering what was involved in fixing the problem.
Also if anyone knows whats the name of the parts ill need.
Thanks,
Alien d2
What brand of rig is it?
Motor size and gearbox type may help those in the know.
Try googling "the brand,transfer,forum" some good information(a little bad) if you hunt.
At a minimum your up for a rear ouput seal but if there is a noise you'll have to do more diagnosing first.
oversite
Sorry Mate,
Its a YN67 Hilux, 1985 with a 3Y engine (2.0L Carby) and a 5 speed transmission.
Its the movement in the shaft that is the problem, I was wondering if the bearing was easy to repace or not and what its called.
Thanks,
345 chippy
pretty sure its a g52 gearbox and the transfer case no.s im nut sure.
if u firstly take drive shaft off then undoo 8 bolts at back of transfer case the rear casing should gently tap off.
pull the bearing and seal out and renew.
the no.s should be on both, if not toyota will have the parts for you.
fairly simple fix (only if you are handy with the tools), otherwise i would take to recomended mec.
good luck m8, hope this helps
cheers 345 chippy
cloughcarib
To reinforce chippy's comment.......you do not need to remove the transfer case to replace this part. You will have to remove at least one drive shaft(I had to remove front and rear when I snapped the output shaft on my last car), and the rear cover of the transfer case
Buy the repair manual for your vehicle and I'll bet that you're surprised at how simple the job is. Just make sure that you do it to the repair manuals instructions.
Clough
oversite
Thanks Guys,
One question before I dive into this, I have to drain the transfer box oil but the drain screw is never going anywear, so when I pull the back of the transfer box (8 bolts) the oil will come out right?
Any ideas on how to stop it going everywhere?
Thanks again.
cloughcarib
Get a cheap long bucket and crack the box with it under. I saw some of these buckets in Bunnings for $3.
Cleanliness is your biggest friend. Before you take out your tools wash of every bit of dust, dirt and the like, pressure wash if you have one, especially the areas above where you are working.
If you've never pulled this transfer case apart, make sure you do the research because there'll be a lot of parts in there and they're all important.
How much mechanical knowledge you have will determine how much research you need to do, but if you find the model plate or stamp on the transfer case then type that into your search bar, then chances are you'll find what I did; that someone has done it before and documented the entire process.
If you find a good link that helped you heaps then post it up here. One day someone might find this post while doing the same job:)
Yogi
Have you checked the uni joints, you'll get a knocking noise from them as well if shot, best to check for the simple things before pulling down the transfer box.
Mike
345 chippy
Mike
like mike said, check your uni's 1st. hopefully for your sake its 1 of them.
and yeh, you must drain oil first, sorry i diddnt mention.
and as clough said, grab yourself a good manual for your truck, it will show you step by step on what to do.
i would b lost in the early years without my manual 4 my 80. its saved me heaps of $$$$$$.
but remember if in doubt take it to a pro.
there are so many bits inside a transfer case that go twang when you open it up.
best o luck 345 chippy
oversite
Thanks guys,
I need a little more help,
I have removed the driveshaft, and undone the 7 bolts around the rear housing, but the but nut is proving difficult to free, I have braced the output shaft so that it wont spin but the nut still wont come out. I am unsure how much force I can put on this, There is a notch in the nut that marks a notch in the bolt (I assume to determine the final position).
Is there a trick to get this undone?
Anyone have any ideas?
Thanks for all your help.
Alien d2
The idea of this setup is once it's tightned you then get a pin punch and knock the edge of the nut into the "notch".
There should be a new nut fitted if it's undone.
To undo destake the nut 1st.
It maybe done up to 100ft/lb.
