transfer case gear box landcruiser
troopy 21
hi everyone just wondering if anyone knows where abouts i could get a transfer case to gear box kit for a troopy? cheers
kruzaman
Put a breather on the transfer case and it will fix your problem if you PM your details I can run you through the process.
cheers
Lee
troopy 21
cheers Lee it wont let send a pm or post my email apparently i need more posts or something. so do you put a breather or run a hose from the gearbox filler plug to the transfer filler plug?
cheers chris
croozza
If you just buy a new intermediate gasket from Toyota and put it in, that will fix your problem, last time I got one it was about $25.00
kruzaman
G'day putting a transfer hose is only treating the symptoms and not the cause and the fix is really quite easy. First the fault, the rear seal on the gearbox (not transfer case) is a standard seal and is only designed to retain oil in the gearbox, when the transfer case gets hot it starts to pressurize because the breather on the transfer case by design is useless the pressure force its way past the output shaft seal into the main box and takes a fine mist of oil with it and slow transfer oil from the transfer case into the main box. Now the fix, looking at the rear of the transfer case from the rear of the vehicle you will see a cover plate with 5 bolts in it towards the top left. this is where the overdrive units bolted onto the 4 speed boxes. remove the bolts and cover obtain a 1/4 bsp x 1/4 barb elbow, drill the right size hole in the middle of the cover and silver solder the fitting in (before soldering just check the angle of the barb so when you fit your breather hose it wont fowl on anything) refit the cover, run a hose up under the bonnet and fit an inline fuel filter on the end of it as a breather filter. then sit back and have a stubbie as the jobs done. I have done quite a few of these breather with 100% success rate. One think to consider with the transfer hose if a leak occurs you will lose the oil out of both the transfer and the main box. Just a little more info on this some time ago we started fitting a double lip two way automatic transmission seal in replace of the out put seal in the main box which stopped the oil transfer but the pressure would build up that much that it would blow the back oil seal out of the transfer case this repair was soon abandoned. I hope this makes sense.
