Toyota's electronic gremlins
Zamunda
I just read the below article in the Pat Callinan magazine about the Toyota 2.8L 1GD-FTV motor (now in Hilux, Prado and Fortuner) going into limp-mode due to dust getting through the filter.
Toyota's response (from the article) - Toyota Australia further went on to say, “as the vehicle is subject to reduced engine power (‘limp mode’) and can continue to be operated safely, it is not a safety related item that would require a recall.”
Toyota has gone further on to say that the problem is caused by very fine dust which "in their opinion" cannot cause harm to the engine. Wonder if they will say the same after several years of use and the warranty period has ended.
Seems Toyota (like all the other brands) don't seem to live in the real world. Imagine this happening in the middle of the outback, or whilst overtaking.
https://mr4x4.com.au/toyota-1gd-ftv-bites-dust/?utm_source=ActiveCampaign&utm_medium=email&utm_content=Toyota+s+2+8-litre+diesel+dust+problem&utm_campaign=PC+Newsletter+#217
mac_man_luke
Be interesting to see if it actually happens in the real world and just just during journalist abuse
Not the first car to have maf sensor issues, almost need to be a service item to give it a quick clean with can of MAF/Electronics cleaner
Zamunda
It had happened to the Mr4x4 team. Here is an excerpt from their article...
"Recently we did a six-vehicle comparison test in the outback of South Australia in Unsealed 4X4, pitting a bunch of current dual-cab utes against one another. During the testing, the HiLux Rugged X test vehicle’s 1GD-FTV dropped into ‘limp mode’ four times due to dust ingress."
mac_man_luke
Yea but they are journalists that want to make a story, often hard on equipment and dont perform any maintenance eg what state was the air filter in?
Zamunda
Not sure about that.
In fairness to the journos, in the comparison test, they actually ranked the Lux second marginally below the Ranger.
Many years ago (back in Africa) I had a Discovery which was a nightmare of electronic issues. The worst of tracks I ever did was corrugations. Every time I went to the dealer their response was "excessive off road use". This was despite their then advertising campaign "best 4x4 by far." Eventually switched brands.
Synchro
Why is this an Electronic Gremlin - it is mechanical - fine dust getting in being detected and the "electronic" gizmo advising there is an issue. Without the "electronic gremlin" advising the driver that there is an issue via going into limp mode you would never know there was a problem and keep driving with possible major damage to the engine.
People blame "electronic gremlins" when 90% of the time they are just a communication means to advise of a mechanical issue. Rarely do the electronics themselves play up these days. Dont shoot the electronic messenger.
rogerazz
So let me get this right. It is not an electronic issue, is just the crap air filtering system and should be recalled to install a better filter system or fix the crap filter system.Doh! :rolleyes:.
shanegtr
Agree, the limp mode is a side affect of another mechanical issue. In reality something like this may or may not end up as a recall - recalls are mainly targeted at safety issues. Depending on how many are actually suffering the same issue out in the real world would depend on if they deem it a significant safety issue to justify a recall. A handful of vehicles playing up isn't an issue - the electronic systems are doing what they are programmed to do and thats protect the engine from damage. I'm not sure how other manufacturers limp mode cuts in, but my Disco its just a sudden reduction in power so Im sure there are better ways to program the limp mode to cut in progressivly if they really wanted to do it
#10
So let me get this right ;)
Toyotas crap air intake system let's fine dust in one end causing engine issues while the crap DPF system belches heaps of white smoke out the other.....:eek::eek:
rogerazz
I drive a Toyota and I like them. However, I also believe that no matter what make, if it does wrong, then can it.
I also don't like it when some people defend a make because they drive it.
I have driven a lot of cars over the past sixty years and I will put sh*t on any car if I reckon it deserves it.:).
2002GU3
It doesn't matter what brand the car is, be it a Lamborghini or a great wall, the car should drive as it is meant to - when you can't drive a new $50k+ 4x4 on a dusty road, that is nothing more than a rip off ........ As for Toyota's "very fine dust won't hurt the motor" BS, I wonder how the general manager would like a handful of bulldust thrown in his motor ?
phs
2.8 has been out a while now and no other reports of it? i dont doubt its a possibility but really need more than once source to see if something is true
Plenty of reports
DPF is a huge issue
Timing chain assembly is an issue a fair few blown motors as a result. We Have not had this issue but plenty have
As for dust yup we got dust and to be honest it has seen very little car following I'd believe this artical as on a Std touring trip you would see heaps
Fine dust won't damage a motor ?????
Were all those 200s letting rocks in were they
It's BS dust is dust if you can see it, it's an issue
Honestly how hard is it to make an airbox m
This is an embarrassment
#15
Yeah imagine of it was another brand with these issues. People wouldn't be so quick to defend it.
I know there unbreakable going over a cliff :p;) but they have to be reliable enough to get there first...
I have been a Toyota fan for as long as I can remember and I know each Manufacturer has there issues, but with ALL the competition around these days I don't like the direction this one is heading in personally.
Bomber2012
2luxes
All air filters have holes in them so air can pass through. These holes will stop dust particles down to a certain size. Anything smaller will pass through and into the engine but it will have been designed to work with it.
I have had enough experience handling Toyota warranty claims to know when something really is wrong they take action quickly to fix it. If they are not concerned about this dust problem then the engine must be working within its design limits.
