Toyota Landcruiser HJ61 VX Sahara 1988
T M Goldie
Goldie HJ61 VX Sahara 1988
Toyota Landcruiser HJ61 VX Sahara, 1988
MODS
Axillary tank
Uniden UHF
Dual Batteries
Old useless floodlights
otherwise pretty standard, so.....
MODS TO COME
2 inch lift kit, new springs front and rear
air bags, rear
winch bumper
12V compressor
33's
GOOD POINTS
It's a HJ61 with 12ht....enough said
BAD POINTS TO FIX
Small rust areas
Surface rust on chassis at rear
Air Con
Rear window washer
T M Goldie
Just downloaded the photo re sizing program, so more to follow and more mods, work on the old girl too no doubt.
This is at Poverty Point campground near Rainbow beach, we had the place to ourselves :)
BOUNCY HJ61
Greetings Tristan,
Goldie Looks Terrific! Would Be Great To See More!
So What Mods Are On The "To Do List"?
Really Like The Window Tint, I'll Have To Put Sun Block On Bouncy Soon.
Any Big Trips Planned?
Cheers Michael
T M Goldie
Hi Michael, mods will be on a 'can I afford it' basis, I have a really good winch laying redundant waiting to be put on to a bar that will be strong enough (not alloy), need to upgrade the suspension soon enough, maybe air bags/body lift.
Planning to go to Jimna this week, Bunya mountains National Park in November and Moreton island for New Year so gearing up for that :D
T M Goldie
Thought I would post up the all important dashboard sort out, sorry no before pics but if you can imagine old tape player under Kenwood stereo head unit (no anti roll so skipping cds) and uniden screwed to the bottom of the dash with extra speaker (not working). It gave me great pleasure to throw the tape player out of the door, mount the UHF in its place and install the ipod compatable Alpine head unit, re wiring the lot and heat shrinking each connection. IMG_0297.JPG Cool:cool:
T M Goldie
This is the high mount winch, I have to remove the solenoid pack and re wire it under the bonnet somewhere apparently, looking for either a suitable cradle or new winch bumper IMG_0294.JPG shame she has an alloy winch bumper
T M Goldie
Some photos of the free Engel fridge, works fine! Given to us when we bought Goldie :)
No before photo, always forget, but it was pretty rusty and discoloured. Took a while to mask it up after sanding and to cut the stencil but...... IMG_0289.JPG
the outcome was pretty good.
T M Goldie
Here's one of Goldie at Cooloola.
Finally sussed out the upload size thanks to Imgur:eek:
No idea how old the fridge is mate
T M Goldie
Yesterday, I managed to fix the rear left window, took the door panel off and realised the problem, the window support bracket was missing:eek:
Reached into the bottom of the door and luckily found the bracket and the two rubber mounts. Took a fair bit of squeezing to get on, but now my eldest Rowan can play at electric windows and have his own natural a/c.
Every little helps :)
T M Goldie
Hi Michael,
Had the system checked, leak found and fixed, gassed with R134a which was in the system already. Was running cold in the back, not working in the front. Now is just not working at all, so will go back to the garage this week. $190 for not fixing the air con seems like a bit of a con really.
The fact is I don't have the skills to deal with air con stuff (depressurizing the system)
don't have the money to face a huge bill for the fix. I am wondering if the previous owner just filled it up with R134a and didn't convert the system thoroughly, not really sure how to find that out either.....maybe someone can shed some light on this for me.
Thanks
Tristan
T M Goldie
An update,
yesterday I replaced a very expensive $40 piece of missing plastic cover from the front of the torque converter (which came from Japan) - no more gaping hole for sand and mud to enter.
Discovered a leak from oil cooler gaskets so they are going to be done on Monday.
Discovered that the tie rod ball joint boot had a split so will replace that at the weekend.
Had the a/c re checked and was told that I need new compressor, dryer etc $1100 bucks. Will use windows this summer I think:rolleyes:
underdog
An update,
Mate, as heavy as that price tag is :( it was 39degrees here yesterday and it's not even summer yet :| good luck without the aircon! The upside is that you might shed some extra weight?! I'm pretty sure we could all use a bit of that. Gotta focus on the positives! :D
jack doff
Gday Goldie
The rig looks sweet mate. I've just bought a VX myself. Its rust free but has transmission probs , not to worry, I just happen to have another trans here.
Is Goldie a 24 or 12 volt? Did you luck out and get the factory cable lockers with it??
Fridge came up a treat, ya cant kill an Engel, especially the older ones.
keep us posted on the mods
:cool:
BOUNCY HJ61
An update,
Greetings Tristan,
At Least The Condenser Is Still Ok, Can They Use R134a With The Original? I'm Pretty Sure I Did, And Haven't Had Any Problems.
Cheers Michael.
