Toyota Landcruiser 60 Series 1983
kalais6
Toyota Landcruiser 60 Series, 1983
Good Points
Its not the complete utter pig I thought it was.
Bad Points
The thing is red yet has a blue passenger front door and guard.
Usual surface rust.
What mods have you done?
She's on dual fuel
Has dual batteries
New re-set leaf springs going in next week
New shocks to go with the above
90ltr OE tank to go in very shortly
Some 33" rubber to make their way under the car hopefully
Why did you buy this vehicle?
Because the other car I'm building is taking too long and I got impatient not having a working toy - and for me its my first foray into the 4WD thing.
How often do you go offroad?
Not enough
I change my mind too often
jbs4wd
Theres a lot of potential there. But even as is still a great 4wd. its taken me about 8 years to get mine nearly the way I want it.
JOHN
kalais6
Thanks guys - few more bits n pieces to fix/replace/fit this weekend - just hope this rain stays away
kalais6
Well for those playing at home, some may have noticed I'd only put up pics showing 1 side of the truck - she had a dirty little secret. Seems the previous owner bent the passenger side front guard and door and replaced them with blue ones. Blue on a red car ??? Not good.
Now as stated I'm using this ride to learn a few bits n pieces so wanted to do the necessary paint n panel myself. At this stage its only got a a couple of coats of the factory freeborn red, but it still needs a few more before I polish it back to get a sheen on it. At least its an improvement and doesnt stick out as much.
I also took the opportunity to sort out the rear bar and tow assembly with a new coat of paint and fitted the new tail lights as the others had gone cloudy and brittle. A bit ticked off the replacement 4WD badge for the gate hasnt come in but that should be here soon.
Also this weekend secured myself a snorkel (not looking forward to fitting this) and scored some 31x10.5x15 mud tyres with about 80% for real cheap as well as some re-set and higher leaf springs so I've still got a small novel of a to do list before I'm happy with her.
kalais6
Small update - new rims in the way of 15x8 black sunnies, new headlight surrounds, indicator assemblies and the roof racks I got have been reworked and fitted along with the spare wheel mount to get that out of the way.
Have a snorkel due any day now, got the gear to do a full service on the engine and chasing some spotties for the front bar
BAZ_747
Looking better already. What snorkel are you using?? where from and how much?? im after a safari for mine.......
kalais6
Thanks Baz - get onto Ebay just now - theres a Safari snorkel (main piece only) going which should go for fairly cheap I reckon.
BAZ_747
id stick with safari , others on e bay for 300(airflow) but id rather pay 150 more and get the safari, looks better too.
What else you got planned for it
kalais6
Sorry Baz - what I was saying is that there are Safari ones coming up 2nd hand on Ebay as well as new. I believe theres a 2nd hand one there now
BAZ_747
can u send a link?? all i can find is new, and its not in sydney.....
if u can please give me item number/s for used ones.....if u dont mind, and if there is more than 1, i dont want to take your catch
cheers
BAZ_747
thanks, just seen em now...old and rough. im prob better off buying new...will keep an eye out.
keep us updated on the 60
cheers mate
kalais6
haha mate I was just happy to get her all the one colour - I dont like unwanted attention.
Thinking about tackling some diff breather extensions tomorrow and finally get this fire extinguisher thrown in the back somewhere
kalais6
ah well done Baz - I'm still waiting for mine to arrive, yay for the delivery service.
On the upside while I was crawling around under the Cruiser the other day I found 2 small diameter lines off the top of each rear shock terminating in a valve block with a traditional tyre valve setup. Pressed the valve in and barely got a hiss back.
Figured it must be air adjustable for varying loads etc - rang a mate of mine who's in the know and apparently these systems were real common...........decades ago :(
Well tonight I hooked the valve up at the local servo and physically watched the back of the truck raise. I'd measured before and after and found at least 1.5inches difference ! The thing rides so much better now too
