Hi Mate,
Thanks for following my build thread. YES, I have had this issue even since I have had my car, the steering on the LN106 is very temperamental and I have had a few little issues with mine mostly related to excessive play in the steering. My steering wheel has changed position whenever I have done any work on the steering. I was able to align the steering wheel a when I replaced the tie rod by turning the wheel straight and adjusting the tie rod length to suit before aligning the wheels. My old tie rod was bent which is what was causing the issue. The steering wheel is still about 10 degrees clockwise which isnt so bad so I just live with it
. My drag link is straight and it does not touch my shocks or leaf spring but it is quite common for the front drag link end to break when steering is at full lock at the same time as the suspension is at full flex, I have had this happen a couple of times. The first time it broke I replaced the drag link with a new straight one and the second time I just rebuilt the ends using a rebuild kit. My suspension lift isnt high enough to justify getting a dropped drag link. My suspension is about as soft and flexxy as you can get which is great offroad but I cant carry much weight without it sagging.
Hope I could be of some help
Thanks Boris,
when you say You broke the front draglink end. Do you mean you broke the ball on the pitman arm? Or broke the cups?
And when you say at full flex do you mean the steering side leaf is fully compressed up towards the bump stop, or fully dropped down away from the bump stop? Because I have been toying with the idea of limiting the travel on the steering side, either by extended bump stop, or by a limiting strap on the shock.
And how do you adjust your draglink cups. Tighten all the way in then back off 1 1/3 as the Toyota manual says? That seems like a lot of play to me.
My springs are pretty soft too, when I first put the susp in I got the front springs a little heavier for the winch and Bulbar with the idea of taking a leaf out if I want. It made it so high though that I had to get a drop draglink. Now I’ve taken a leaf out I probably don’t need it any more though.
I’ve found it easiest to just pop the steering wheel off to align it. I didn’t think you can straighten the wheel with the tie rod adjustment. That only adjusts your toe in?
I’m more concerned about when I’ve been off-road and then my s wheel goes to a different position, meaning something in my steering set up has moved.
Sorry about all the questions, but I really appreciate your feed back. I can see from from your build thread you’ve got a bit of nous, and I don’t personally know many who own a solid axle Hilux.
