Toyota Dyna Gera box in Hi Lux
Mongrel Lux
I have a 2.8 Diesel Hi Lux with a DTS Turbo & a stuffed Lux gear box. Matt from GOR told me Marks Adaptors has a fully reconditioned Toyota Dyna gear box wich has been adapted to bolt straight into a 2.8 D Hi Lux but have to modify the floor pan a bit to make it fit as it's a bigger box but the bolt & stud patten's the same, same spline to match my H/D clutch, so every thing lines up.
A Dyna is a light truck so it's a bit lower geared than the std Lux box I think? But how much lower I wonder:confused: My gear box was re-built on 5 / 8 / 09 & H/D cluch fitted.
Has anyone ever put a Toyota Dyna Gear Box into a Hi Lux? I'm looking for the best option as I'm not sure if the std Hi Lux gear box is strong enough for 33s + turbo combination?
Any thoughts?
Mal
Mongrel Lux
Mmm, Good point. I'll ask tomorrow, Marks Adaptors told Matt from GOR that the gearing is almost the same but a bit lower. So maybe Marks Adaptors have changed the ratios a bit. I'll have to check on that.
Thanks for your input Jarh73. Anyone else got any thoughts or advice?
Mal
Croozer
My old motocross van was a toyota dyna light truck with a holden 6 in it Mal. The gearing was standard except for first was hardly ever used. Sounds like Matt has put you on to a great Idea. Is it a five speed box? If Marks are doing them it must be a great combo. Keep us updated.
Cheers Bruce
Mongrel Lux
Thanks Croozer, so ya saying that 2nd to 5th were the same as standard but 1st was much lower? Marks might have replaced 1st with something more usefull maybe.
I'll let ya know what I find out. Matt told me that the Marks Adaptors Dyna gear box is full reco including bell housing complete $2,800 + labour to fit it. So I'm open to other options
Jarh73
Just take off in second gear and enjoy having a true crawler gear!
Is yours a daily driver?
Second gear will be like your current first gear. As a rough guess.
Justin
Mongrel Lux
No Justin it's not my daily drive any more. Just weekend warrior & I run 2 sets of tyres, 31s for turing as I can get 800 kms of low range 4wding out of one tank & about 1,200 kms in 2wd. I only get 400 with the 33s on.
Mal
Jarh73
I think you might be fine with the dyna gearbox.
You will never break it that's for sure and think of the abuse those little dyna tip trucks and concrete trucks must put up with.
I also think having an extra low first gear is really really worthwhile.
Justin
Mongrel Lux
Cheers Bruce
No Bruce Matt from GOR didn't put me on to the idea, a bloke on the Aust 4WD Action forum said:- " I've heard of one other bloke that this has happened to a couple of times but he was towing an excavator/Bobcat. He's now replaced it with a Toyota Dyna gearbox & the Holden V6 punts the whole lot along very nicely. Aparently the Dyna gear box, along with being much much tuffer also has excellent 1st & 2nd gear ratios for crawling. Might be worth looking into? " So I put the question to Matt & he looked into it & this is what he found out:-
Marks Adaptors have converted the Dyna gear box to suit the 2.8 Hi Lux. The Dyna gear box has side shift selector linkages the Lux box has top shift selector. So Marks made a new selector housing so the Hi Lux gear stick & transfer case lever will plug staight in to it. The standard Hi Lux transfer case is kept unchanged & in the same spot.
The Dyna gear box is the same length as the Hi Lux but is bigger around the girth so the cross member is lowered by 12mm & the back of the floor pan is modified slightly- then it just bolts straight in. The Marks kit comes with 1/2" spacers that go between the cross member & the chassis, & longer High Tensile bolts to refit it.
The Dyna's 1st gear is much lower than the Hi Lux & Mark's have not changed that, but 2nd to 5th are all about the same as the Hi Lux.
I asked about the V6 Hi Lux gear box & it's too long & requires too many mods to make it fit in a 4 cyl Lux, & it's not much stronger so it's not an option.
Matt at GOR has been great, I asked him about a week ago, he didn't know in fact he'd never heared the idea before :confused: But he took the time to find out all he could.
Dyna option all up fitted about $3,800 + or - if a mechanic fits it, less if DIY. & ya right Justin you'll never break it & it wont break anything else.
Mal
g/box
HI Mal,
I had a the same dyna gear box fitted behind a Holden vn v6 in a 1988 4 runner it worked fine however what i have found out searching the internet is that the dyna gearbox (R452) is NOT ANY STRONGER than the R150 g/box or R151 g/box it just has a lower 1st and 2nd gear ratio
R150F-found behind Toyota turbo diesel surf/v6 4 runners
Ratios:
First Gear: 3.830:1
Second Gear: 2.062:1
Third Gear: 1.436:1
Fourth Gear: 1.00:1
Fifth Gear: 0.838:1
R151F found behind V6 4runners/turbo deisal prado/100sreies L/cruiserHzJ78/79 7 later mod hiluxes
Ratios:
First Gear: 4.313:1
Second Gear: 2.330:1
Third Gear: 1.436:1
Fourth Gear: 1.00:1
Fifth Gear: 0.838:1
R452(Dyna g/box)
1st 5.15:1
2nd 2.87:1
3rd 1.50:1
4th 1:1
5th 0.83:1 or 17% overdrive.
It might be worth considering these other gearboxes as they are considerably cheaper.
Anyway food for thought
In fact you can put the internal cluster gears from the dyna g/box(R452) into the R150/151 GEARBOX and you not only get the lower 1st & 2nd gears but increase the 5th gear over drive from 17% to 30%
All the r series boxes have interchangeable internals
I run the R150 gearbox behind my vt v6 in the surf and it handles the power really well
Hope this helps cheers mark any Q’S--0403987379
PS i want first dibs your rock sliders if ya sell em LOL:D:D:D:D:D:D:D
All went well I take it Mark ????
hi Jack, my appoligies i thought i had sent out a Multi Txt to let people know i am home.
yes they removed the right bit and my sense of smell, i hope it will be short lived as my taste is muted as well:(:(
Also i am not allowed to drive for 6 weeks & no alcohol:(:(:(:(
Catch ya on the flip side
Cheers mark
oznog05
Hi Mal,
I have the 3.0TD duel cab and always thought it would be good to increase the final gear as. Let us know how you go. Will be also interesting to see how your fuel consumption is altered, or if at all.
Mutley, Do you know anyone who has converted there boxes in a KZN169, I assuming it runs the R151 box?
Might have to give Matty a call down at GOR!
r151
HI OZNOG, I PERSONALLY DONT KNOW ANYONE who has converted a r150/151 box to with the r452 clusters, but i did find on line a guy who has done the conversion using the Supra box R154, when i find him again i will put up the link.
He was asking the question why does marks 4wd adapters go to all the trouble of converting the dyna box (changeing the shift mechanism/adapting a transfer case etc) when the internal cluster gears sets fit into the R150/151 boxes, all shifters remain the same plus you get the added increase in over drive;overall the R series boxes are a good strong box!!!
I do know trying to track down a dyna gearbox is very difficult, unless you buy a complete truck:(:(:(
Cheers mark
Big Matt
Cheers mark
He goes to the trouble because it's easy to do with cad and a cnc machine and he prolly hopes those who do the swap don't realize you can swap internals as he dosnt do a kit for that
