After skipworth iv descided to go ahead with phase 3 of the sawnoff build. This will include (in no particular order as money presents itself!)
Fittment of GQ patrol drive axles which are wider and heavier then the 75 series. I already have these but still need to build the diff centres.
Remove leaf spring suspension and replace with coil springs (probly only about 3") with 3 link front and 4 link rear setup. This will make it sit comfortably lower then it is now and give it a much nicer ride. I already have the 3" coils and all the links.
Adapt gq transfer case to 75 gearbox. This will then allign the drive shafts with the drive axles which will eliminate any driveshaft phasing problems and will have original park brake system in place. Already have the gq transfer case, the adapter is happening as we speak.
Cut front guards and modify tray to fit 37's on full flex with only 3"lift. Ill just recess and widen the guards in the tray rather then lifting whole tray.
Make bigger fuel tank. For obvious reasons.
Intercooler. Most likely water to air which will least compramise the diesel gas system.
Fix up interior. Put a carpet floor in as its just a bare metal floor, upholster the rest of the cab as that is also bare metal. Put in a nice pair of seats, the current ones are worn out original seats with ripped padding, and broken bases!
Fit air-con system. Purely becase i want it!
Build cannopy for the tray complete with a rooftop tent and a sealed section to keep gear dry thru deep crossings.
Lots of other odds and ends to tidy things up a bit to make it.more touring ready rather then a trail rig (but just as capable!)
