Toyota 4 Runner SR5 limited 1994
struth
Toyota 4 Runner SR5 limited, 1994
Good Points
Good comfortable car in standard trim with mild lift and 33s, good low range gearing with the chain driven transfer too. A bit over modified for long range touring, does the Hi Country real well, but not so comfy on the drive along the hiway to get there and back.
Bad Points
Small when touring with wife and two kiddies. Original rear axle bearings and seals prone to failure when loaded for touring. Original rear brake shoes easily begin failing when water and mud are involved, especially making the handbrake useless.
What mods have you done?
VT commodore 5.0 Lt EFI V8. 60 series rear diff to cope with the V8 and get rid of the bearing failure issue. SAS with 60 series front diff on 3 link setup. Rear disc brake conversion with Subaru calipers. 2" body lift and 3" sus lift. Custom tube bars all round, custom rear drawr set. Rhino roof basket. HID spotties and 20" light bar. Custom snorkel. Custom sub tank 60 lt. 35" Claws. Twin air locks and 4:88 gears. Hi Mount winch.
Front diff housing upper shave to allow for more up travel. Shave both diffs at the bottom for better clearence. Transmission handbrake for better holding on rocky hills. Curri style rear sway bar to tighten the rear articulation and force the front to work a bit better.
Why did you buy this vehicle?
It was low Ks and clean as a whistle, plus I like 4 Runners.
How often do you go offroad?
Not often enough anymore.
80 or GU
struth
Thanks guys, on a 65 Lt tank I get just over 300km.
So on my 120 Lt total I get 600 normal or 475 Hi Country. Not the most economical setup around but I don't mind.
struth
I used to get 430km per tank from the original V6, a lot of people wouldn't believe me as most were lucky to get 350km. The 3VZE is great in lo range just suffered from a lack of power on road. But it was economical in compariosn to the 8.
GPS Guru
One thing to watch is where the roof joins the D pillars. I ended up with cracks on mine. It was a 1994 model, brand new and the rear suspension sagged by 10,000 km after towing three trail bikes to Merrijig. So replaced with Old Man Emu. Then I discovered the cracks. Toyota didn't want to know about it, even though it was still under warranty. So I ended up in the small claims tribunal with engineering reports etc. saying how it was bronzed welded and a weak point. Unfortunately not being overly mechanically minded, the bloke from Toyota said that the A pillars (the front ones) didn't crack because I didn't change the suspension at the front. Trouble was I couldn't because it was a torsion bar setup, which of course I failed to pick up and subsequently lost. My only avenue of appeal was the Supreme Court and that would be too expensive.
Other issues I had:
Starter motor failed out in the bush (fortunately on a hill)
Fuel pump failed
Cruise control failed
Internal lights failed
4 WD indication failed
Airconditioning failed
Indicator kept on falling out of the right front mudguard (Toyota fixed it by packing it with a bit of newspaper)
It did have comfortable seats though!
Incidentally, I ran into the bloke from Toyota that was at the Small Claims Tribunal at a party a few weeks later and went over to him and said hello. But he decided to avoid me and said that his wife needed company and kept away from me for the rest of the night.
Nice looking rig that you have there though.
struth
Mate you must have got a lemon for sure.
I know 8 other people with 4 Runners and Surfs who have not suffered any of the issues you have.
That said the cars aren't perfect, especially the original V6s.
My roof should be ok because it coped this about 2 years ago now,
happy times
prawns
Crikey mate nice job :)
Tuff looking truck with lots of blood and sweat put in - Thats great mate well done and what a great outcome she was definatly worth it from what Im seeing :)
Would love to hear it going on a youtube clip as well......
