Toyota 4 Runner 1990
Gatti
Toyota 4 Runner, 1990
Good Points
Plenty of fun to be had!
Bad Points
What mods have you done?
Reco'd 2.8 Diesel
Denco Turbo Kit
4 inch lift
Rancho 9000 adjustable shocks
33 inch tyres
CB Radio
Turbo Timer
Full Stereo system including reverse camera
2.5 inch exhaust
Dual Batteries
Add some LED Campsite lighting
EGT and Boost Gauge
Drawers in the back
Why did you buy this vehicle?
To get out of the city!
How often do you go offroad?
I try to do it weekly work and family permitting
LowLux
Nice one, like it, like it. Couple of questions if that's alright. DId you install the turbo timer and was it hard to do? and do you find having the spotties covering the grille, that the temp rises more than usual?
Gatti
Thanks mate.
I didn't install the turbo timer, so I am not sure how hard it is to do.
As for the spotlights I haven't had any overheating issues at all, and that's even though it doesn't have a fan shroud either. The temp is alway nice and stable.
Gatti
Got an early Fathers Day gift today. SAAS Boost Gauge
It shows the boost maxes out at 13 to 14 psi.
Is that what a Denco kit usually put's out, or has it had the boost raised?
ERASER
you should seriously look into dropping the boost to 9 psi, someone has raised the boost. 9 psi is the max recommended for a 2.8 without causing damage. Also get that shroud fitted before summer hits.
Gatti
Cheers mate.
It reaches 13 PSI when I get the revs right up.
I never rev the thing over around 3k so the boost is at 9 or 10 PSI there. Do you reckon that's o.k?
I am planning on fitting a shroud as you've suggested, just to be safe.
ERASER
When your going up a hill, like Mt Victoria you going to keep the revs up and the boost will climb. Get it wound back to 9psi and fuel adjusted to suit to keep egts down. Over 9psi is not ok and will cause damage and wear the engine out real quick.
Gatti
On another note, I have wired the gauge off the same power as my CB but this means the gauge lights up as soon as I switch on accessories.
Does anyone know where I can get power for it so the gauge only lights up when I turn on the headlights?
Gatti
Today I have had a bit more of a fiddle around with my boost gauge set up.
I had the vacuum line coming out of the manifold from the point in the picture below. I used the T piece supplied with the gauge and plugged one end. This ended up being a bit too close to the intake pipe so I wanted to move it. This is where the gauge was showing 12 to 13 PSI.
I re plumbed the vacuum line as shown below, and the gauge now shows around 9.5 maximum which is where it should be.
I can't figure out the reason for different readings. Any ideas?
I also tried getting power for the gauge from the back of the das light dimmer and it worked, but as soon as I attached the dimmer switch back on it lost power??
Gatti
Thanks guys.
I am happy with the Ranchos. They are easy to adjust and there is a lot of difference in feel between the settings.
Gatti
I haven't posted in this thread for a long time so I thought I'd update it.
Below is a couple of pics of how it looks now with an awning and High Lift Jack fitted.
I have also added some drawers and a caged divider in the back (the sub easily unplugs to make space when needed)
I am also after some opinions on how I have fitted my 33" spare under the rear today.
I started by removing one of the factory brackets, but kept one to keep the tyre away from the exhaust.
Then I wound up the new spare into position using the winch.
Now the issue I had was that fully inflated it would just rub a little on the pan hard bar, so I dropped the pressure to 20 PSI and then attached a ratchet strap and used it to squeeze the tyre against the rear of the tow bar to make it clear the pan hard.
The strap looks close to the exhaust in this pic but it has plenty of clearance.
Using the dropped tyre pressure and strap I now have this much clearance and if I bounce the rear of the car it doesn't hit the pan hard at all.
What do you guys think? I know I could get a rear bar with a tyre carrier but I'm too much of a tight arse! :)
