I thought our Hilux year is pretty solid compared to later Tritons etc..
They are like any chassis, they have been designed to do a job and they will do it. They are fairly heavily built in the centre and around the front suspension but there is not a lot in them once you go back past the front hangers for the rear springs.
If you look through the towing section in the owner's handbook, you will see that a WDH is listed as being essential for any ball weight above 90 kg. That is not a lot of weight to have hanging off the end of the car but Toyota says it must be supported. You may not be towing anything but the weight of accessories like spare wheel carriers and their wheels, plus whatever is in about the last 300 mm of the tray might as well be on the tow ball. They are suspended pretty well directly above it and the wheels will be back past it.
The standard rear springs are very soft and flexible but they still work. A couple of years ago I had mine (a single cab ) loaded to the maximum carrying capacity of both axles. That is just over 200 kg above GVM. I always travel at around 200 kg under GVM and that is on standard suspension.
On this particular occasion the tray was full of scrap metal for a church collection. There was a tyre changing machine at the front of the tray. In addition to that I had car batteries, radiators, brass plumbing fittings, about 40 kgs of copper wire, thousands of crushed aluminium cans, alloy car wheels, a lot of aluminium car parts and about forty dismantled lawn mower engines.
My wife and I added 140kg and there was some recovery gear, a big HF radio and a few other things under and behind the seats. Those few things combined added about 25 to 30 more kilos.
Despite all of this weight, the tray was still sloping down ever so slightly to the front. There was also plenty of clearance between the rear bump rubbers and the chassis. The reason for the absence of rear end sag was the load consisted of so many small pieces that I was able to distribute it very evenly. Unfortunately this is a lot harder to achieve when you are loading a car up for long distance trips. It is easy to end up with the rear end sagging.
The solution is to add after market springs or air bags. The car is now level but it is operating outside its design limits and reliability is reduced but it may create a few handling problems as well.
Have a look at the last and third last post in this discussion.
http://caravanersforum.com/viewtopic.php?f=2&t=22776&p=347673&hilit=bump+steering#p347673
I noticed the rear springs on mine do not have all that much of an arc in them. I haven’t tried mounting any cameras on them yet to see what happens whenI go around a corner with a load on them. I wouldn’t mind betting that they go into a reverse arc like the spring in the photo.
Are heavier springs going to do the same thing? If not are you going to get an increase in roll understeer like Toyota, and no doubt all the other manufacturers, intended?
