Different extension bar colours for different tensions . You just need to avoid the silver ones lolNearly every mechanic I know uses these Style extensions.
So from a distance it will always look like a full noise rattle gun.
Got anything from the current centuryI had a blow out on the way to Brisbane a few weeks ago , this was after having a wheel alignment done just prior . I could not undo the nuts by my self . I had to get another fat guy to stand on it while I got stuck in to it too. so the torque specks were rattle gun tight . This is about were they should be although please look for specs inside your owners manual first. View attachment 42908
You would be hard pushed finding a torque wrench without imperial settings because a major portion of world wide industry still use imperial . its not hard at all to convert from metric to imperial . Primary school level of education today addresses this . I did say to refer to your own owners manual before using that spec sheet as people have already said there is a huge range of torque settings with the same stud size. Nuts and rim design change a lot . check out the Toyota specs above then compare them to the lug nut chart .Got anything from the current century. Inches, ft-lb, inches again, what does that all mean?
Tink
