solder/crimp
I'll keep it simple, nearly every electrical failure I have to fix on heavy vehicles is due to aftermarket cluey autoleky fitting something and soldering and guess what solder joint failed!
I'm tired of these clown let me put frankly when I have to go out in the middle of the night when "B Double" is stranded on the side of the road with electrical failure because some toser who knows better decided to solder something on to trucks electrical system.
I don't use $10 toy crimping pliers nor I'm advocating such. I use professional $200 + crimping pliers and I had no fail yet! Heck I even use "el cheapo" ones ($60) and still have no fail.
Correct soldering requires skill to do properly, anyone can master to squeeze pliers.
This bloke has done the hard yards NOTE WELL decent crimping tool is $200!!!
so is a half decent soldering iron !!!! solder is also pretty different !!!
as is flux !! Killed spirits AKA Bakers fluid is OUT for ANY electrical work!!!
Old fashioned ( if ya even find it today ) soft Rosin ( yep pine tree say !!! ) in a tin I havent seen for years. Rosin cored solder ( VERY often MISPELLED Resin cored solder) comes in at least 2 easy to get varieties that I know of
50/50, and 60/40
The numbers mean the amount of tin and lead used in the alloy.
50/50 is best for auto use. 60/40 is for circuit boards.
50/50 is harder to use because it melts at a much higher temperature to 60/40.
60/40 has more tin (60% ) so it flows easier and covers dry joints MUCH more successfully than 50/50
DECENT auto sparkeys are like gold hens teeth, and I DONT mean any disrespect !!! ANY auto sparky that has even ONE SINGLE Scotch lock or its even NASTIER chinese equivelent has learnt NOTHING at all, and any repairs or accessory fitting WILL FAIL Ill put bloody money on it.
There are times when you need soldering, AND there are times to use crimps
a " decent auto sparky will ( or should ) explain the difference and quote accordingly.
This is maybe off topic, but its been my life since about age 8! and I take GREAT pride in all things electrical, when I make it.
NO SUCH THING as half arsed electrical!!!
with high voltage it will kill you !!!
with low voltage it can leave you stranded
BAD auto electrical work can require a complete new loom ( extreme case )
THEN you need somebody that can REPLACE the loom where the factory intended it.
NOT draped over your extractors !!!
Joe
