TMR rules on single, centrally-mounted, LED light bars
hotgemini
This came across my desk and would be relevant to a lot of 4wders
Due to link restrictions I can't post the below text as a link... top work forum admins...
So the document is called VSI HV25.0 Driving Lamps.pdf, but due to forum restrictions you don't get to see the original, so you'll just have to take my word that it says;
Vehicle Standards Instruction (Heavy Vehicle 25.0)
September 2012
Light Emitting Diode (LED) Light Bar on Front Bumper or Bull Bar
The Department of Transport and Main Roads (TMR) has recently dealt with a number of issues relating to the
fitment of LED light bar to the front bumper bar and bull bar on some vehicles. TMR is providing the following
advice to assist vehicle owners to comply with the regulatory requirements.
The fitting of lights and light signalling devices on vehicles (other than motorcycles and motor trikes) must
comply with the Australian Design Rule (ADR) 13/00 and the relevant requirements of the Transport
Operations (Road Use Management—Vehicle Standards and Safety) Regulation 2010 (the VSS Regulation).
Neither of these specifically deals with the fitment and use of LED light bar. ADR13/00 provides for fitting and
use of optional lamps, including driving lamps. Where the fitment of a lamp is indicated as optional, this means
that it is not mandatory to fit the lamp, but if fitted, the lamp(s) is/are required to comply with the ADR.
In addition to the main-beam (driving) and the low-beam (passing) headlamps, additional driving lamps may be
installed as long as they comply with the following requirements:
• Two or four driving lamps may be installed;
• Any additional driving lamps must only be used in conjunction with the main-beam (driving) headlamps. • Driving lamps must be at the front of the vehicle and fitted in such a way that the light from them does
not cause discomfort to the driver either directly or indirectly through the rear-view mirrors and/or other
reflecting surfaces of the vehicle;
• The driving lamps must be able to be lit only when the main-beam headlamp switch is in “ON” position;
• The colour of the light emitted by driving lamps should be white;
• Driving lamps fitted are not required to comply with ADR 46/00 which contains the photometric
requirements headlamps;
• ADR13/00 requires that driving lamps, if fitted, must be fitted in one or two pairs.
Under the ADR 13/00 requirements, the minimum distance between two lights constituting a pair is 600mm,
measured from the inner edges of the illuminating surfaces. While this specific requirement does not apply to
driving lamps, it is strongly recommended that the LED light bars, when fitted as pairs, should be fitted in a way
that complies with the distance requirement as closely as practicable.
In cases where a single LED light bar is fitted in the centre as one continuous light unit, the requirement to fit
driving lamps in pairs could be easily met by fitting an opaque cover plate at the centre of the light bar to
simulate the appearance of two separate light units. The width of such opaque dividing cover should be
enough to distinguish the arrangement as two separate light units. For example, the ability of an observer
standing 200m in front of the vehicle to perceive the light bar as two separate light units may be used as an
approximate guide.
Example of an opaque dividing cover that may be fitted in the centre.
Moratorium for vehicles fitted with a single LED light bar type driving lamp
To allow vehicle operators sufficient time to understand and implement the requirements in this information
bulletin, TMR is placing a twelve month moratorium on the active enforcement of the requirement that vehicles
fitted with LED light bar type driving light(s) should have those lights fitted in pairs, pending consideration of
changes to ADR13/00.
The moratorium applies only if the driving light(s) comply with all the other requirements mentioned above,
except for the requirement to have the lamps fitted in pairs. Operators are, however, encouraged to take note
of the requirements in this information bulletin and carry out the simple modification, if required, to meet the
intent of the regulation. Vehicle operators should be aware that this moratorium only operates in Queensland
and vehicle operators may still be subject to enforcement action in other states and territories.
There are also pictures included, but again, due to forum restrictions you don't get to see them either. Hope this help.
PJR NSW
Banned
Thanks for the post.
I was wondering when this would happen. And when do other states do the same. It also seems like they are sticking to not allowing lights on the roof.
Ah well.
Phil
