TJM vs ARB - Air Lockers???
forbytime
hey guys,
i understand this is a FAQ in the air locker section but could find any threads on here.
Who has what and which is a better unit to go for, TJM or ARB ?????
as im looking to buy one for my 4runner :)
Cheers.
Towie
Opposite Lock - Elocker IMO
There are a gazillion threads on Lockers to research from just change the words you use in the search function and they will appear.
fearnot
what shall I do?
Hi I've got a 1995 2WD Toyota Hilux Ute & I'm not shore which would be better the ARB or the TJM Air locker because I've beefed up the rest of my Ute to take 1.5-2.0m of wood in the back of it & sometimes with the normal Diff with a winter tread type tyres I need some more grip in the mud.
Plus I've asked around where I live about Elockers & no one gets them so I'm left with ether a Air locker or a LSD but I think the Air Locker is a lot better for me what do you think?
I'd go the Lokka by Goannawhere,They do a LSD replacement locker...A lot cheaper than air etc etc...Will do the same job..
read how it works here :
LOKKA Differential Locker | 4WD Systems | Gear to Goannawhere
http://www.4wdsystems.com.au/pdf/toyota-lsd.pdf
Goodluck ;)
Guido_s
I couldn;t justify the cost of an air locker.
Everything I've read has pointed me towards the Lokka - I've ordered a front Lokka today for the Patrol GU from 4x4Systems.
At $348 - how do you go past it?????
Guido
fearnot
OK Swaggie that's fine with you but who supply's the Lokka Diffs because I'm limited to what I can get in my state I ether a LSD or a Air Locker to put in my rear axle other than my normal Diff because no one knows much on what to put into my Diff to help me:(
Not sure i like the tone of your reply mate..But anyway go to the site and call them...It doesn't matter what state you live regarding any product (that's ridiculous)...I am sure they can steer you in the right direction at 4wd systems...If they cannot i was only trying to help.
Also there is Detroit Locker etc etc....
Goodluck
red hilux
I've got twin air lockers in my surf and yes I've had problems with the air delivery side to the rear locker. But this is now resolved.
Another problem I'm experiencing with mine (even now) is my air compressor. For some reason the compressor leaks. It's really weird though. I can turn it on and it wont stop running. Turn it off and try again 10 min later. It's starts then stops. Try hour later and it's perfect.
If I was to choose between arb or tjm. I would try the e locker next
Mine was doing weird things,Its either a wiring issue (that was my issue,wired by ARB)....Or maybe your pressure switch on the compressor !
Bypass the pressure switch to see if its ok (pull wires of it and join)...
Goodluck
fearnot
I've got one problem Swaggie my Ute doesn't have a LSD in it at all from New all it has in it was a Normal Diff that if it starts sliping I'm had it.
Guido_s
Fearnot,
The guys from goannawhere can be found @ 4wdsystems.com.au - re Lokka's.
They're located in the northern suburbs only a couple of kms from Adelaide.
Sorry don't know their phone number. The website is pretty comprehensive & I'm sure you'll find the list with the range of vehicles.
When I was talking to them today - they were telling me that it's not unusual for the guys in the bush and remote areas who don't have mechanics handy to pop out the diff, box it up and send it to 4wdsystems where they'll fit the Lokka and send it back fitted to the diff for fitting.
Give them a buzz and have a chat -they seem a pretty good bunch of guys.
Guido
fearnot
there is only one problem with that Guido_s is that don't have any other Car except my Mums Car & I can get an Air Locker fitted in my Ute in 48 hours with no problems unless there is a place in Victoria that can do the same thing for me Mate.
struth
Mate you should be able to get a Lokka for your non LSD diff, as said, one would be ideal for your circumstances. Give the sellers a call and ask.
Towie
Any half decent mechanic can fit that style of Locker.
$400 is the going rate so call them & then you will know exactly where you stand.
Literally any Mechanic should have NO problem fitting it - They are nothing like the complicated air lockers to fit.
moose maverick
Yesterday I installed a Lokka in the font diff of my GQ had the diff centre out in about an hour. I replaced the cross shaft in the diff, it only had minimal wear but it was out so I did it. I rebuilt my swivel hubs with new bearings and seals, replaced wheel bearings and got it all back together in a day. Drive in to drive out was about 11 hours. If you didnt do the extra stuff but just replaced necessary seals it would be about 5-6 hours. If you are going to do it yourself and its a front lokka remember to get new hub seals, cv and axle tube seals or else it will be coming out again when it leaks.
Goodluck ;)
Hey guys im new round here but i used to work for ARB,i toying with the idea of putting a locker in my jackaroo but i just read up about the lokka and it seems the goods my only concern with it is when your on the road and on harder surfaces, how does it not lock up to stop skipping tyres and chewing tyres. the theory sounds great just wanna know its not gonna be a drama later.......????
fearnot
Shadowman_182231 I had the same thing in the back of my mind but I couldn't think of what to say at the time because I haven't dun enough finding out into it at the time even if I've got a 2WD Ute so I talked to a Diff person & told them where I live & what I'm going to do with it & they told me to not use the Lokka or a LSD it wouldn't be any use to me to use & put in a ARB or a TJM Air Locker go figger?
Jackolux
I have 2 x ARB Air Lockers in my Hilux thats all I could get at the time , oil pissin bloody things , only lock when they want to ,
fearnot
Yea Jackolux I was told about that from the Diff Person that was the only thing that is why I was told to go for the TJM Air locker they don't have that problem but there Air Compressors is another thing though.
