Titan drawers in 76 series 2010
Does anyone know if there are already bolt down points underneath the carpet in a 76 series for drawers etc, or do I have to drill holes to bolt them down?
I would rather not drill holes, so if anyone else has any ideas that would be grand!
I have found these tied down points which would work very n8cely as well.
Unfortunately you have to do the hard work & get underneath the vehicle when fitting these thing!
You shriek when you drill into the body & bolt it in but It is what it is!
I just fitted a fridge slide & single draw to my vehicle.
Just make sure you treat & spray the drill holes & check all areas under the body before drilling from above.
Dont drill into the fuel tank ;)
I ended up just using the four existing tie down points instead! Works perfectly!
