Time to get my hands dirty
WILDTI
With the TI needing the valve shims to be done & knowing it is a massive job I thought I would give it a go.
3 weeks ago the TI was parked in the workshop of Gippsland Offroad to measure the valve clearances whilst cold, once measured the boys started to take the shims out to measure them with me watching rather closely. We couldn't get some of the replacement shims for 3 weeks so everything was put back together till they were in.
The replacement shims came in last Wednesday so it was time to organize a time to put them in & shuffle around some of the other shims, with Matt being rather busy I thought I would give it a good crack at trying to do it myself. I started to unplug & unscrew everything to get to the rocker cover, once I was at the point of starting to replace/move the valve shims I sat down & went over my notes again for the 4th time just to make sure my measurements were correct.
I started working on the TI at 3pm friday & worked through to 11pm. got all 23 valve shims done, I got a little help from Matt (tappets) & Martin with the number 6 exhaust shim because it's a bugger to get to & has very little room to get into. We decided to put it back together Saturday & do the running temperature valve clearance measurements. 9am Saturday morning everything was put back together to warm the car to running temperature, Ryan (UncleFryzy), Bruce I had to shuffle 4 of the shims to get it to the point where we were happy with it, time to put it back together & in no time at all it was ready to give it a test drive at 5pm, all good. About 20 hours of work later all the valve shims were done & I'm a happy camper because i now know how to do the shims on my truck, I'm glad it only needs to be done about every 70,000 odd kms but next time I will have to replace the head with a gas head.
Thanks to the Guys Matt, Martin & Ryan in guiding me how to do it!!!
cptmud
good on you, its a big job, if its anything like the cruiser. You should be congratulated on a job well done
Jarh73
I recently found out that the adjustment of the valves on my 2.8 GU is exactly the same method.
I know who to PM for advice now :)
Justin
WILDTI
Justin
LOL for sure.
I did mine (only replaced them) in 20 hrs & you still have to take into consideration that time again to measure & do the working out as to what needs replacing & if you can move some. feel free to call Gippsland Offroad 5943 1020 for any info
I must say I have done my fair share of these 4.8 s and toyota shims ,it is not an easy job nor a straight forwrd job to be done correctly .
I will say well done elise excellent job considering we only pointed you in the direction .
Croozer
Well done babe, great job. Now start doing crown wheel and pinions so you can fix the crewman. lol
In all seriousness great job Elise and thanks guys for guiding her in the right direction.
Traveller
Hell yeah, a few lining up already for your 'apprenticeship' - ready for the clutch on a GU yet??
Well done too by the way!
WILDTI
We got Genuine shims & will only use them, there weren't any in the country of the sizes that we needed so it took a little bit of time for them to come in
I use only genuine shims so yes it took about 3 weeks ex japan ,and no non genuine shims are not ok as I have seen and another customer has also seen with a 4.8 non genuine case hardenied shims are no where as good as genuine case hardened shims causing all sorts of expensive repair bills out of trying to save a few $$ . and again well done elsie
millsy
Well done on a good job, and a tricky one by the sound of it! I wish my old back and knees could bend like that! Certainly lets you get in close to the action!
Too bad Patrol's don't come with a side cam and the good old hydraulic lifters.
With the old VH Commodore it was very easy. Just a trip to the local hardware shop for a packet of 5/16washers. One washer under each bolt and the hydraulic lifters had enough 'cushion' to take up any slack! Just a couple of hours at the most, if that.
But it just gave me another 6 months driving if I remember rightly, and then had to take the head in for a reconditioning. Am going through the same thing on my current VH motor. Have done eleven of the 12 valves. The last one gave me trouble because the socket would not grip the bolt head and so I couldn't undo it! The bolt is rounded off I think, for some strange reason. Might have to try aralditing a socket onto it maybe, unless anyone can give me a better option?
Am also hoping that the horrible exhaust noise might be a warped exhaust manifold not mating up to the cylinder head properly. Might take it down to the mechanic to analyse it properly for me. But too busy having fun with the Patrol to be bothered right now. Maybe next year!
WILDTI
I was willing to wait 3 weeks for the genuine shims to come in, it wasn't as if the shims were left out when they were measured so all that was needed was to put the rocker cover back on & put the rest back together that only took about an hour to do.
WILDTI
I tell you my hips, knees, legs, arms, hang on I may as well say my whole body is hurting for being in the same position for so long & I'm covered in bruises from my grease monkey playing
Croozer
If anyone see's my Mrs she is black and blue from her car not me ...lmao! I try and give her a hug and she screamed lol! Her shins look like she has been playing hockey without gaurds.
I am very proud of my girl and she knows what I complain about from day to day when I come home from work and have had to rebuild a silly flameproof forklift. In all sorts of silly positions with skinned knuckles and cuts etc etc.
But its all part of the fun and games.
WILDTI
When you go to scrub off the grease & you realize it's a bruise you know it's a job well done LOL
millsy
At least I don't get the bruises. Maybe I am not trying hard enough. When you get older you always think of the easiest way to do something - your body/bones/muscles/knuckles come first, the hour hand on the clock comes second!
Trouble is now my finger joints always let me know when I have had too much fun pulling things apart and putting them back together. JeanSA ( acka HM ) reckons the arthritis is setting in. So I'm throwing back the glucosamine tablets now instead of the Green Ginger wine.
I reckon there are two jobs I love playing at but would hate to do full time - mechanicing and truck driving. The mechanics have to tolerate the wear and tear on their bodies ( I bet they get the arthritis before they deserve to ) plus the stress of finishing the job on time.
And the truckies are in the same boat. The wear and tear on their back bone as they put up with the rough roads and the load shoving and jarring them from behind. I hitched a few rides once from Broken Hill back to Adelaide when one of my beloved Torana's died out there. The last 100km was with a truckie in an old Mercedies cab-over. Gee I was glad to get out of that cab. My back has never been the same! And he did that trip 2 or 3 times a day, all week long!
And of course they are under time stress too as they try to get their loads delivered on time. I think they are both tough and very brave to be working in an 'office' that is doing 100 clicks all day long!
