Tigerz 11 Free Spooling problem.
jack48
Just fitted a new winch, works great except for free spooling.
Takes 2 to pull it out, have been told a possible reason but what are you thoughts ?????
Has only done test after installation and one recovery :(:(:rolleyes:
Watt
Hey Jack, I had an issue with mine... it was the handle not disengaging properly.
Unscrew the Handle and there will be a tiny rubber ring under it... Either put it in properly or leave it out which i did... then screw the handle back on.
Should free spool sweet after that if thats the same problem...
jack48
Thanks Hayden, guess you had the same problem, have taken note of what you suggested, but the winch will have to be removed to do that and if that is the case I aint doing it.
It can be done under warrantee.
I was told by supplier of said winch that it is not mounted square LOL its on a 10 ml plate and mounted sideways, had no probs with other winch except the solinoids didn't work, shall fix it and mount it on the back .
cptmud
Had a similar problem with mine, was due to an ingress of water into the gear box,it had washed out the grease and it had all rusted up inside. Going to get a new gearbox for it, but just run it out under power atm
Big Matt
He only put it in last week, and its a brand spanker so that shouldn't be the problem (one would hope anyway LOL)
Im not sure how the low mount gearbox is sealed, but if its not to bad you could try pressurizing it to keep water out ?
jack48
Hey Axel, got it new in box on Thursday and fitted it in the afternoon, checked it worked, powered out and in, wiring OK.
So Saturday morning tried and did unspool 20 mts up a steep driveway, boy was that hard, thought to self, must be wound too tight and forgot about it.
Went for a 4x4 drive Sunday, Hard to extreme tracks, and the main reason for a new winch for just in case, well it was needed urgently, Tonkadore hovering on an end for end roll over, it took two guys and a lot of strength to pull the cable out, not a good situation.
canyonaro MK1
i have a tigerz 12000lb with rope, i find that if it is used under load (as in when used to get out of a spot:rolleyes:) the rope gets really squashed onto the spool and is hard to pull out. Solution; I always run the rope out when i get home and wash it with fresh water and dry it in the shade before i put it back onto the winch. this seems to stop the rope being "sticky".:)
Does this help?:confused::confused:
Big Matt
Ive been told that about rope. Needs to be cleaned and dried or its gets mouldy and ruins the rope
jack48
Thanks but it doesnt help. It wsas a brand new in the box 12000 lb unit, run out twice, I have used a few and decided time to go rope :):):(:(
Watt
Yeah the rope does get tight but when you get a change to wind it out and respool it under load... start neat for a couple of full spools and then go zig zaging all over the place so its hard for the rope to interlock itself.
We have a rope winch on our big wood chipper for work... its been through a lot of shit and gets wet a lot. still fine, havent ever washed it or dried it out when wet.
If my winch rope gets wet i try to dry it but then you end up having to spool it back on unloaded which isn't great for the next recovery.
The rope on the tigerz winch would take a fair beating before any real damage is done...
If you have the time to look after your gear why not do it...
canyonaro MK1
trouble is it still gets wet when sitting there when it rains
Yeah i hear ya, thou, only the top of the spool seems to get wet in the rain.:confused::D you run it out and its dry 2 layers down. even after a drink in a river it's only wet a couple of layers.:D
canyonaro MK1
When i'm respooling it it's put back on dragging a tire full of sand up the driveway just to put a little load on it;)
