Silveredition
Thanks for the comments / suggestions / opinions offered so far - all have been taken on board!
This morning I have managed to have a little play with it. As far as an additional on/off switch / pressure switch goes - I don’t think it is needed. The compressor has a 120psi cut out on it already. When the end hose section is disconnected (the tyre end with the gauge attached - about 300mm long) the compressor cuts out after a couple of seconds (I assume at 120psi). All I need to do is to convert the end to a clip on style, with a trigger. This will effectively turn the compressor off when the trigger isn’t compressed, or when it is removed from the valve....
I have had a bit of a look inside the compressor - it appears to be greased (with a clear grease) well in places, and not so well in others - there was also a fair bit of swarf above the pistons (on and around what I assume are the reed valves). I haven’t managed to take it apart far enough to find the air intake yet...
Will have another play with it tomorrow....
