Things to avoid when buying a Camper Trailer
There are plenty of things that can go wrong with camper trailers from construction to accessories. While reading another post, Maurice mentioned to avoid a particular build issue, I thought others that have camper trailers will be able to add to the list so when members buy one they can take a checklist..
Sometimes price won't allow some features but at least your aware and can possibly fix yourself. Comments about build only please.. Like below.
A list of things to consider when purchasing a camper trailer:
1: Avoid any with bolt on then weld draw-bars unless you camp at caravan parks (maurice)
2: Drill holes through Aluminum for wiring to have rubber grommets. (swaggie )
3: I ordered powder coated. I wish I spent the extra and had it cold galvanised. (toddyh)
4: Pinch weld seals beat foam seals. (toddyh)
5: Grease nipples on bearings and joints are handy. (toddyh)
6: Same size wheels and tyres as tow vehicle. (goldrush)
7: Same track (wheel to wheel width) as tow vehicle. (goldrush)
8: Long drawbar (Easier to reverse). (goldrush)
Very true but the downside to a long draw bar is that it is more likely to bottom out in steep/difficult terrain. Depends on where you will use the trailer I guess. (toddyh)
Long drawbars are usually fitted with extra gear/storage boxes along it - increasing drawbar weight - something to be very aware of. (chris_stoffa)
9: Bash plates if water tanks fitted underneath. (goldrush)
10: Ease of setup. Is there a quick overnight setup as well as full campsite setup (goldrush)
11: Storage space. Is there enough for all the other gear you need? (goldrush)
12: Weight distribution needs to be considered for balance and towing (chris_stoffa)
13: Removable jockey wheel that is the first point of damage on the draw bar (marty e)
14: Also make sure the seller of secondhand trailer supplies Safety Certificate and gas cert on purchase otherwise the reg will not be transferable in Queensland if it is over 750kg (gaff)
15: Make all jerry/gas holders on the side with hinged access. Nothing more frustrating than having to open the tent base to get something out (cloughcarib)
Although if they are under the edge of the camper they are very hard for some scumbag to steal (chris_stoffa)
Fair point, but most over-center latches have provision for a lock (cloughcarib)
16: when comparing Campers check the thickness of the chassis steel, as certain cheaper ones out there have very thin chassis and the end result is brocken suspension or shock hinges. (redandy3575)
17: I would always ensure the Brake components are Alko or similar and available in Australia. (CampingTechAust)
18: a few manufacturers, use 75x50x3 for the drawbar and 50x50x3 for the chassis, even with the "offroad " models. The more extreme models(all had independent suspension) has 100x75x3 drawbars and 75x50x3 chassis's, and some had the above but used 4mm thick steel. (03hilux)
19:
Toddyh
I got powder coated. I wish I spent the extra and got galvanised. After my first big trip I ground it back and coated with cold gal anyway.
sent from the world out there
goldrush
Ease of setup. Is there a quick overnight setup as well as full campsite setup?
chris_stoffa
Gaff
cloughcarib
Make all jerry/gas holders on the side with hinged access. Nothing more frustrating than having to open the tent base to get something out.
Great Advice there guys I'll post your recommendations in a list in my first post so anyone can just print off from it.
redandy3575
One more....when comparing Campers check the thickness of the chassis steel, as certain cheaper ones out there have very thin chassis and the end result is brocken suspension or shock hinges.
One brand which i'll mention for good reasons are the Camel Campers that have a thick chassis rail throughout the whole lenght of the trailer. They're a bit dearer than most, but are built to last.
jack48
Stay away from a certain brand of trailer, I am unable to tell you, but we left ours in the desert, broken, unable to be towed, dumped. You can quess the brand, available in Vic.
rainsey
Sorry, from NSW... Not wanting to ask for the name but a hint might be good.. Starts with?
Kindest regards
Rainsey
Sent from my iPad using Tapatalk HD
underdog
Kindest regards
Rainsey
Before anyone drops an obvious hint, can I suggest PM'ing the company in question instead of posting anything publicly. For the sake of the forum guys ;)
Hi All,
I would always ensure the Brake components are Alko or similar and available in Australia. I know a guy who ended up with crap Chinese Brake components on his camper which he had to replace at his cost even thought the supplied Brakes were defective.
Yes, he took it back under warranty.
No they didn't fix them properly
Yes, he went to consumer affairs
No, Consumer Affairs were not able to get resolution and the next step was court....
Yes, he felt ripped off.
Hi Andy
Have you an idea what they use, cheap might be 3mm and decent 4.5mm, or does anyone else know the specs...
03hilux
Hi Andy
Wayne, when I researched before I began building my own, the vast majority of manufacturers, such as Jonnos, camel, Redback, just to name a few, use 75x50x3 for the drawbar and 50x50x3 for the chassis, even with the "offroad " models. The more extreme models(all had independent suspension) has 100x75x3 drawbars and 75x50x3 chassis's, and some had the above but used 4mm thick steel.
He can't say but it was imported
Gee, I can see this needing to tread very lightly.
