Mitsubishi Australia
The key to a great 4WD is a great drivetrain; that is, the system which delivers the power from the engine to the wheels and is responsible for much of the driving performance you feel in your vehicle. The new 2016 Mitsubishi Triton has a thoroughly engineered drivetrain system capable of tackling almost any terrain. Matched with the newly-developed 4N15 MIVEC powerplant is a new 6-speed manual transmission, as well as an all-new 5-speed automatic transmission with Sport Mode and an improved torque capacity. With this combination greater responsiveness, faster torque delivery and significantly improved acceleration feel has been delivered in the 2016 Triton.
The new Triton’s 5-speed automatic transmission has been a close development with the performance proven Aisin AW Series 5-speed automatic transmission as seen in the Mitsubishi Pajero. This means that the same 4WD handling and reliability from the Pajero is offered in the 2016 Triton. Plus, there is no longer any torque limitation on any AT Triton variant, as well as a unique shift schedule and torque converter lock-up characteristic to ensure every Triton model will deliver ground-breaking performance on any drive and in any situation.
The all-new 6-speed manual transmission in the 2016 Triton features a passenger car-like short shift stroke and a reduced shifting operation force. This dramatically improves the driving comfort of the 2016 Triton, particularly when driving long distances or through treacherous terrain. In addition, triple cone synchromesh has been integrated into 1st, 2nd and 3rd gear to facilitate smoother gear changes and reduce the synchronisation phase. Smoother shifts mean there is less wear on driveline components, especially at low gears when the torque through the drivetrain is highest. Shorter synchronisation times help to increase efficiency by keeping the time between gear changes as low as possible.
The 2016 Triton’s differential implements a revised 4WD gear reduction ratio from 1.9 to a new 2.566 reduction ratio on all 4WD models for better torque delivery characteristics as well as a significantly improved low range 4WD performance and feel.
Meanwhile, the Super Select 4WD II system offers a revised front-to-rear driving force distribution in 4H, or Full-Time 4WD mode, for improved running stability and cornering performance as well as excellent traction in unpredictable road conditions.
With these new developments in the gearbox and differential systems, the 2016 Mitsubishi Triton will deliver greater driving performance and reliability than ever before.
For more information about the all-new 2016 Mitsubishi Triton, click HERE.
Or visit: http://www.mitsubishi-motors.com.au/vehicles/triton
