the end of my 60 ute
Daryl2457
My old girl (60 series) and I where involved in a head on collision with a driver 4 times over the limit, I was stationary at a intersection waiting to turn right,as the car in front moved off this pissed wanker in a gq patrol came screaming around the corner crossed the centre line and collided directly with the drivers side front of mine.
The bullbar took the brunt of the force but smashed the headlight,grill,indicator it also bent the guard and bonnet. So now according to the insurance its a total economical loss.the plus is that I get paid out and get to buy mine back
V__38D0.jpg the old girl made a meal of the patrol
Daryl2457
So now i have a problem,i went on the hunt for a new 60 as my body is beyond help with rust i just keep chasing my tail.i have found another one that's very very clean a little to clean to chop for the ute but too clean to pass. so i guess my 60 ute will become parts
it is a 3f petrol on gas so I will swap it out with my turbo 2h diesel. So I have a lot of research to do as I'm not sure what is required.
Daryl2457
Thanks guys.i have a big build ahead with fitting all my accessories plus the diesel the idea of the wagon is slowly growing on me, but I'm really going to miss the ute
Alien d2
Just a thought, could you swap the wagon body onto your chassis?
This could be easier then changing the motor/lines/tank etc., effectively your using your existing drive train.
It also depends on how the insurance wrote it of (to be able to use the chassis number).
Daryl2457
In victoria any vehicle Over 15 yrs old doesn't get registered with Vic roads as a write off even if its stuffed. body swaps in Vic are not allowed, I will put more research into it there maybe a loop hole
4runnerSteve
With the complete old 60 a conversion shouldn't be a problem, just everything out, everything in. The only problem is it takes a lot of time. The damage to the front of the ute doesn't look too bad to me, How hard would it be to pull the bulbar back out and straighten out those panels, new light and its good? I would probably just fix the light and pull the bar straight and off you go, especially if it didn't get registered as a write off.
ian.c
Bad luck with the accident mate, I'll keep an eye on this thread and help out where I can, earlier question about the gearbox, it is definitely the same, should be a h55
5 speed. however the bellhousing will be different.
Chatty
Well that would have to tick you write off - oops, I meant right off :p
I do feel your pain, but that wagon looks pretty tidy for the age. Good luck with swapping everything over - at least it will be a good project and a chance to find any "issues" you may not have been aware of. :D
Is it worth trying to hold to find a diesel vehicle, given the time it will take to swap the engine over? o_O
I've had utes, I have wagons. Now firmly committed to wagons. For the moment. :rolleyes: Only possibly looking at utes again for tow capacity (because no way I could afford a 200 series) but not sure I will go there. :D;)
Daryl2457
Thanks guys, at the risk of sounding like a young wanker(which I'm 31). I've had a moment of clarity and decided(with help from you guys and my health issues would make it hard to do major work) I'm going to keep both the way they are and have both on the road, ill panel beat the damage on the ute, forget about the rust issue for the moment and it can be my bush beast and the wagon with the 3f will be my daily and long distance tourer in the factory form it is now with only rear draws as the only serious addition
4runnerSteve
As far as I'm aware the 3F is a pig of a motor on fuel, the cost to run it might have you reconsidering its role as a long range tourer. If you get into it soon the rust can be contained, and depending on how bad it is solved almost entirely. For a quick fix clean the car really well and drench the underside/wherever it is rusty with a phosphoric acid solution (available from Bunnings) then leave it a day or so, clean off any excess residue and paint it with a rattle can of rustoleum or similar. Worth a try, it could help the ute hold together without major work for a long time yet.
Daryl2457
Thanks mate, the rust is in the rain channels and in the edge of the roof I guess ill have to pull the roof lining but ill definitely treat it with the acid. I have heard the same about the 3f's I was thinking I might give mine a try as its duel fuel and hoping it might be affordable
4runnerSteve
I just assumed the rust was in the underside/chassis, not really sure why. Phosphoric acid rust converter is awesome stuff it just destroys rust. I wish i took a heap of before and after photos of stuff i used it on, it comes up like a whole new part on manifolds, harmonic balancers, spacer plates, pulleys and the like. It didn't hurt the paint on mine either, but that was with wiping it off about 10 minutes after.
I missed the on gas bit before too.
Daryl2457
Lol no its all good, I'll still give the roof a dose of acid and a paint on the inside of the roof.I have heard molasses bath is also a great rust remover but you have to leave the part submerged for a decent period of time, I might also struggle to find a bath big enough for the 60 lol :)
