The 3.5T towing myth is getting out of hand (Drop your specs below, I’ll run the math for you)
TowingMate
G'day everyone,
Been spending a lot of time analyzing towing setups lately, and honestly, the marketing BS around "3.5-tonne towing capacity" on modern dual-cab utes is getting downright dangerous. I’m seeing so many blokes out on the tracks who are massively overweight and completely voiding their insurance without even realizing it.
Let’s do some quick pub math on a typical setup.
You buy a new Ranger or D-Max. The brochure says 3.5T towing. You hook up a 2.8T caravan. The tow ball weight on that is roughly 280kg.
Here’s the trap a lot of newbies miss: that 280kg comes straight off your ute’s payload.
If your ute has a 950kg payload, you’re instantly down to 670kg.
Add a steel bullbar and winch (100kg)
Add a canopy and dual batteries (150kg)
Add yourself, the missus, and two kids (250kg)
Add a fridge full of food and a few beers (40kg)
Suddenly, you have about 130kg left. That means if you chuck a full tank of fuel and some recovery gear in the back, you are legally overweight. And that's before you've even packed your clothes or a BBQ.
Manual calculations are an absolute headache with GVM, GCM, and Rear Axle limits. Because I’m a bit of a data nerd, I actually built a custom script/calculator for myself just to figure this out without going crazy.
If anyone here is second-guessing their rig or planning a new build, drop your Tow Vehicle model, Caravan ATM, and Tow Ball weight below.
I’ll run the numbers through my system and tell you exactly how many kilos of payload you actually have left. Better to be safe than cop a massive fine!
Cheers.
Aren’t commercials tared with a full tank of juice?
Yes, the rigs you see that are laughable are very common, fuel or not.
TowingMate
Spot on mate, good catch! Technically 'Kerb Weight' includes a full tank of juice and all fluids, while 'Tare Weight' usually only factors in about 10L depending on the manufacturer. But exactly like you said, fuel or no fuel, the margins are so razor-thin that a couple of slabs of beer or a heavy fiberglass canopy can easily push these rigs over GVM. It's crazy how fast it adds up! What rig are you touring in at the moment?
Been out of hand for a very long time and the fines these days are not very much a couple of thousand at the most roughly depending on the state.
Current bt50 with a touring canopy and now a roof top tent since I no longer have the rear fold camper. In full desert crossing trim with the long range tank full I’m definitely over for the first few days until I burn some water and diesel. The setup isn’t over the top so I’m usually all good. I go to the dump a bit and watch my weights - somewhat.
JamesO1979
G'day everyone,
I’ll run the numbers through my system and tell you exactly how many kilos of payload you actually have left. Better to be safe than cop a massive fine! On another note, I’ve noticed https://mostbet.com.pk getting mentioned around some of the forums lately. Not really related to towing, but I’ve seen a few people discussing it as an option for sports betting when they’re not out working on the rig.
Cheers.
This is a good point, especially because the advertised 3.5T towing figure is only one part of the equation. The numbers that matter are the vehicle's actual loaded mass, GVM, GCM, rear axle limit and tow-ball rating, not just the headline towing capacity.
I'd also be careful about using the brochure payload as the starting point. Accessories, passengers, fuel and other permanent additions can vary the actual available payload significantly, so weighing the loaded ute and caravan is really the best way to know where you stand.
For anyone doing the calculation, I'd keep a record of the actual tow-ball weight as well. A caravan that's 2.8T ATM doesn't necessarily put exactly 280kg on the ball, and loading can change that considerably. A certified weighbridge is cheap insurance compared with finding out you're overweight after the fact.
The calculator idea is useful, but I'd treat it as a planning tool rather than a substitute for the manufacturer's ratings or an actual weigh-in. Those limits are there for a reason, and being under the advertised towing capacity doesn't automatically mean the complete combination is legal or safe.
Every set up is different the towball weight can be changed to suit if it doesn't effect the handling.
The guide recommends 10% because of our rough road conditions and 5% for good roads that's what they use to say many yrs ago. I had a set up years ago where I had 6% towball weight on single axle 1.4t loaded van and it road extremely well. It was a pop top so less wind drag and movement from cross winds.
A set of bathroom scales can measure the weight depending on their limit with piece of ply to spread the load but may not be good for larger vans.
Conversely off road biased trailers want well over the 10% to allow supple suspension setups.
A couple of days ago I passed an Audi suv it may have been the Q7 towing a tripe axle caravan that was impressively long. Wow it looked pretty small in front of the van can't figure out how that would be safe that's Dodge Ram territory.
