Test drove a few 4wds today
red hilux
I manages to test drive a couple 4wds today
Ive ranked the cars
1. 2018 triton
2. 2018 merc ute
3. 2018 paj sport
4. 2018 v6 amarok
The triton and merc ute were most comfy on the test track. The merc interior is more refined, while the triton's lllooonngg rear end hits a few times. Ive still placed the triton over the merc purely becasue of cost to buy. I just cant see myself spending that much for a ute.
Paj sport. While having the same engine and gearbox, I just found the sport more laggy, and also the suspension didnt feel as nice as the trition and merc
2018 amarok. on this test track, it was not nice. A very harsh ride ( might need to get my spine adjusted jokes ), very laggy engine
all utes were unloaded at time of testing
phs
Ive ranked the cars
1. 2018 triton
2. 2018 merc ute
3. 2018 paj sport
4. 2018 v6 amarok
Never driven any of them but Surprised the V6rok was laggy
mikehzz
Pajero Sport doesn't have the same gearbox, an 8 speed auto against the 5 speed auto or 6 speed manual in the Triton. Where did you drive them out of interest?
CaptainBanana
The new triton has a 6 speed auto and the pajero an 8 speed. The current 5 speed is used in Landcruiser, hilux and pajeros and actually works well in terms of ratios matched to the triton motor. If you're loaded up though it does shift firmer than most modern autos and it has a big stall speed which shows up more when loaded up.
CaptainBanana
And no doubt a cooked trans without an extra cooler and heaps of extra fuel, no good for towing if it does that with just the car loaded
With my usual load for work it's manageable with very small throttle inputs but even a head wind down eastlink kicks it back off the lock up and flaring. It does have a good factory cooler but that's a fix for the high stall speed which is a fix for its low tourqe output at low rpm, a slipping converter allows for more rpm and boost. Also with its massive overhang heavy ball weights can lower the bum a bit which makes the steering a bit sketchy in some conditions.
Other things worth mentioning are the front end cannot be lifted more than about 35mm or you Max out the droop bump stop, if you fit a shorter bumpstop or cut yours you regain some droop and reduce bump steer but you still don't have much lift. The solution is a uca swap, diff drop and coil overs so add about 3k + engineering.
The factory tyre size is 29.5 inches which makes the speedo nearly 10kph out and also makes it impossible to go up 2 inches in diameter as every single combo ends up about 3-4mm over the allowed 50mm. The available legal fitments are quite a step down. I really wish I'd checked my numbers better on the tyre front.
Whatever you save buying a triton youll spend making it fit for your needs unless you're actually going to keep it stock and relatively unloaded.
Rhett HS
Not sure if you want a ute or wagon? Makes it tougher to decide. Wagons should be ahead on comfort, but have other drawbacks to weigh up.
Maybe you could test drive a navara next. Similar to merc but better value. Halfway between the merc and triton.
