Tanami Pro - Fuel Transfer Pump
extremelimitsoff
Hi all
Now available is the Tanami Pro Fuel Transfer Pump
The units look great and work a treat, No more lifting Jerries to the filler point.
Never Lift A Jerry Can Again!!
No moving parts
Runs with 12 V air compressor or foot/hand pump
Powdercoated body resists corrosion
Empties a 20lt Jerry Can in minutes
Tested with Petrol Using 72 LPM 12v "Max Volume" air compressor
Specifications:
No internal moving parts
Operates with air pressure as low as 2-5 psi
Air inlet: Schrader Valve
Safety: Pressure relief valve
Outlet: 10 mm pipe with 2m fuel grade hose
For low pressure/volume 12 volt air pumps
