Tailshaft Issues
SNagorcka
Hi, I have a 2006 Nissan Navara D22 3.0 Manual - I have just had the tailshaft done up and balanced and after refitting I have noticed that the centre bearing is hot to touch. I have rang the company who did the reco on the tailshaft and they have advised that it may be hot for a while until it seats itself. I honestly do not believe a centre bearing should get hot, but would really appreciate feedback from anybody who has gone through the same repairs and let me know there thoughts?
A bearing seating its self is a BS line from the workshop in my opinion.
Ring another tail shaft specialist, there are plenty, just check reviews before ringing and ask if a hot center bearing is normal
SNagorcka
Thank you for your reply. We agree, but we cannot seem to be able to find anybody who has actually found this problem before; so therefore they don't know what is causing it to happen and have no advice as to how to fix it.
CaptainBanana
If you have heat it's a due to friction and bearings are there to eliminate friction so common sense suggest someone is not doing good quality work
typhoeus
but, bearings do get warm with use, feel your wheel bearings after a drive, how hot is hot?
I found some info that said it shouldn't exceed around 80c not sure how accurate that is but what temp is it running at you may need to go for a good drive and use a temp probe or a heat gun to get an accurate reading before approaching other companies. Also remember it runs at a very high speed so it's going to get pretty warm and with ambient heat, heat off the road the exhaust and engine all may contribute every bit counts.
