Made a table to clip onto the tie down rail got the idea from another member on here so thanks Albynsw. I decided to make a small one for now to see how it goes 650 x 400 mm. Picked up some Connect-it 25 mm box alloy, plastic corners which are in the same area, 25 mm white plastic clips and a 100 mm gate bracket from bunnings had the alloy sheet and adjustable tent pole at home. Assembled the table cut the leg to suit and fitted it upside down so the outside leg would fit into the storage clip, allowed extra length for raising the vehicle in the future and riveted it together. Used metal screws on the plastic clips I was surprised how stable it is when set up good enough for a stove etc.
