(SYD) First 4X4
gach2
Just got my first 4x4
1990 Toyota 4runner
2.4 petrol carb 22r (not my first choice either but if offroading becomes more than just a phase, i would be looking at selling this and getting a 2.4td or 3 litre version)
Came with 33 inch BF Goodrich a/t tyres
As for suspension im unsure what it is. Shocks and springs are yellow so there aftermarket but no idea if they are upgrade/lift or not (nothing new anyway).
4X4s pretty banged up and in need of some work
Clutch is on the way out (still drivable)
Idles pretty rough, so far have adjusted the idle up so it doesnt stall at lights (tacho is not working either so probably set at 1000-1500rpm idle)
First time driving a 4x4, and im pretty use to driving cars quiet low so atm feels pretty wierd and unstable to me driving up so high, so prob want to get used to that before i head out into offroading.
As its my first time offroad, want to start a bit basic, even if its just travelling on the beach etc - would having a worn clutch (doesnt slip too bad atm but the pressure point is all the way up atm) be big issue? bit tight for cash atm and want to take it to the beach before rego runs out in 2 weeks.
Any other recomendations (really easy places to go offroad etc in sydney)
Heres a pic
Toddyh
Depends where in Sydney you are. North side your best bet would be head up the central coast to the Watagans. West side your best bet would be Newnes SF from Clarence. South side probably Belanglo SF.
As for beaches pretty much the only real option is Stockton. Will cost you $10 for a 3 day permit. Go in from the Anna Bay end (north) as the sand there is firmer.
ElectricBug
Nice kit, will scrub up nicely with added accessories.
Find out what you need before you load it up with things you won't use.
Welcome to the Forum!
cloughcarib
Yes,Yes,Yes.
Great advice.
Welcome.
Drive it on a few trails before you decide where/when to put your money. What one person recommends may not be right for you.
Enjoy
RoughNReady
Yep, but the basics are good. Which I don't have yet. Getting there. Shhh.
e:
I forgot to say, I alternate between a low, auto LWB V8 and a light manual SWB 4wd with all the column controls and ignition barrel swapped over sides. You;ll be fine. You're probably already noticing that you can actually see at intersections.
I grew up in the country and bush around 4x4s. You'll be right as long as you use your head.
