Suzuki Grand Vitara - HELP
Jodes27
Hi Everyone,
Well I am quite new to the world of 4x4.....I've just bought a 2006 Grand Vitara having got rid of my boring little city car....however, and this is going to sound REALLY REALLY DUMB ( but I don't care cos I need help!) But I think I've bought the wrong car! :eek:
I basically wanted a 4x4 for some general offroading (not too hard core...yet) and mainly beach driving (I'm looking to be able to get up to wedge (a couple of hours outside of perth) Anyway in my research I realised that the newer Vitara's had the switch in them to go to low range, they didn't have the actual low range gear stick like in the older models - what I didn't realise was that in the 2006 model - it only had low range in the 5 door - not the 3 door (which is what I have!) So now I have this great little car which I love - but don't really know if its going to be capable of doing what I want it to do, being only a constant 4wd and not having low range
Does anyone else have a similar car to this? Can I do modifications to make it better for offroad? Or am I totally screwed and need to trade it in for something else ( which I don't really want to do)
PLEASE HELP!
Thanks in advance :)
bmurray2250
Hi Jodes27 and welcome
I was at the belief the Vitara had low range but that shouldn't stop you. I have been on Fraser Island and seen xtrails and other 4x4 that don't have low range. This may stop you going into difficult areas where low range is an advantage. General offroad activities I don't engaged my Prado into locked 4x4 (Prado is a AWD with low range) only when the track becomes more challenging and if it becomes difficult I engage low range.
Grumpy
Welcome aboard Jodes, it shouldn't bother u a great deal unless u intend on doing some serious 4x4ing.
Grumpy
Type in Grand Vitara into a search engine and have a read, some good points made in the results.
Jodes27
Thanks Guys. :D:D
Yep, my understanding was that the Grand Vitaras all had low range. However, on further research the 2006 1.6L 3Door Grand Vitara does not, its just a constant 4wd (I'm guessing this is the same as AWD?) - in this year only the 5 door model has low range! Argh!
I've been doing a fair bit of reading about them but a lot of the info I've found has been to do with the larger V6 Grand Vitara 5 doors with the low range. I've been trying to find out if there are any modifications I can do to mine to make it better for offroading - mainly beach driving. I'm guessing that the best I can probably do is lift it (?? excuse my very non technical terms) and get some really good tyres? I do love this car - although I guess I bought it a little too impulsively, I guess for a very 1st 4wd it'll be ok. I use the Toyota Landcruisers at work and have some experience with them - not a huge amount though.
I guess I can just have a crack at it and see how the Suzuki goes - if i get ridiculously stuck I guess I better make sure I bring a shovel! :eek:
croozza
you canset the suzi up well if you just fit a lift kit, you will only get about a 1 to 1 1/2 inch lift though, fit some good all terrain tyres (dont get mud terrain as you will only be going on sand and MT tyres dig in more), some bar work, good recovery points and your set. I believe the early 3 door didn'y have the low range because the gearbox from the 5 door was too long, however they later on made a new box for it so if you can track one down it will fit. $$$$$ is anyones guess, and that is what it will come down to, but if all else fails sell it and cut your losses and get a 5 door.
Jodes27
Thanks for the help - I guess I'll just have to have to have a look around and see what I can do with it ;)
I'll check out those websites too - thanks rod :)
