Sure Power
Snorkle Steve
Just came back from my first trip with my dual battery setup running the Engel, All was well until the 3rd or 4th day when the battery went flat, every day i went into town thinking i was charging both batteries but the sure power solenoid didnt seem to be switching over, I was wondering if any one else has had the same problem? is it because my start battery is old and wont reach full charge to open solenoid or have arb sold me a dud? Any help for a solution would be great.
Cheers.
Davidman
Hi Steve
Depending on whether the system was self installed or installed at ARB / elsewhere, I would suggest taking it back and have them test the system. They should be able to pinpoint the issue.
rodw
You'd need to check the voltage on the AUX battery while driving to make sure the Solonoid cuts in. Mine usually only takes a few seconds (<30) to start charging. I use th evoltmeter in my GME UHF to monitor this as it is wired to the AUX battery.
It is possible that either:
a) Your crank battery is stuffed and absorbing all power so the voltage never goes high enough to trip the solonoid
b) You stuffed the AUX battery by discharging it too deeply. I don't think the Engel has a low voltage cutout like the Waecos.
If they are not sealed units get a $3 hygrometer from SuperChaep and measure the State of charge of both batteries.
drivesafe
Hi Steve, you say you drove into town everyday, unless you drove for at least 30 minutes in each direction, you would not have put much into your auxiliary battery and without knowing how much power you draw from your auxiliary battery each night, but you would probably need at least an hours drive in each direction to charger the battery.
BTW, it’s unlikely that your cranking battery would have any effect on the operation of the isolator, no matter how old the battery is. The fact that your could start your motor indicates the cranking battery is still working.
4WDN
After my auxiliary battery was stuffed by being over tightened, not knowing that it was not working properly. the best thing i done was put a moniter in so i know how much charge the battreys have ,and what is working and beeing charged. I now dont have to leave home on a big trip without knowing something is not working.
Snorkle Steve
Thank for all the advice, at the moment its working as one big battery as i haven't got aroung to fixing it, will def be fitting a moniter though, also going to get a bigger altinator down the track also, I'll try a few things and see how it goes over the long w/e and let you all know how i went next week.
frosty
I run an Engal battery voltage cutoff/monitor in my trailer. It's set to cut power at 10.5 volts. It also has a digital readout. Does both jobs. I run 2 50lt Wacoes of the battery. they last about 4 days before the isolater cuts them off. I then just run the truck for an hour and get at least a day or so. Might be worth a look at.
Snorkle Steve
The real problem was i didn't have a good earth on the 2nd battery so it wasn't charging.... im just glad it fixed now and no more flat batteries!!!
