Sub Tank
ozne
I have a GU Patrol 3.0 Litre Turbo Diesal. Recently the Sub Tank has been emptying itself. I have had the Patrol for over 12 months and the emptying of the sub tank has always been at mt control as it was alwys full as filled. I know that every time you start the Patrol it is set up to release a small amount from the sub tank so as to keep the pump primed and operational. Has anyone else had this problem and what is the fix.
Offrdn60
G'day,
If you can't get an answer from here, you could try the patrol forum under the GU section.
