Stupid mistakes not limited to 4WDing
Zukiman
Not sure if this is the correct category to put this is, so Mods feel free to move if necessary....
Driving to work this morning, after the heavy rainfall all night there was a certain amount of flooding, mostly due to the sodden ground and the runoff just building up. Thus, flash floods on roads that are usually ok. But certain roads in my area flood fairly easily and regularly, even just during natural rainfall periods in winter. And that brings me to our problem this morning.
The road in question has two old, wooden, single lane bridges located at the base of hills, about 500m apart and crossing two creeks which meet up downstream. The first is at the bottom of a fairly shallow grade, long approach with very visible sight lines on both sides, and was about a foot deep with fairly fast running water. Nothing too troubling, as i said it is a common occurence for these bridges to go slightly under and most people would cross at this stage, even standard sedans. I will point out that both bridges are very old, made of wooden sleepers, with larger sleepers as edging on either side and a flimsy post and single rail fence to indicate the edge of the bridge. Each is only about 15ft long.
So crossed the first bridge no issues, and was approaching the second bridge after cresting the hill in between. Second bridge is much steeper, is located on a bend on both sides which restricts view of bridge, and the creek is much deeper and faster here due to the geography of the properties on either side. As i approach this bridge (slowly, single lane give way from this side), i notice two people standing on the side of the road at the apex of approach corner. As i catch a view of the bridge, i notice two cars, one parked on the opposite side of the road, rear to the creek, and one smack dab in the middle of the bridge with water halfway up its doors. Obviously attempted the very deep, very fast water and stalled halfway, and had been pushed up against the downstream edging. The edging is only about half the height if the average wheel, just enough to bounce you back into the centre of the bridge if you get too close to the edge. Not a very stable position to be with large amounts of water pressing against the opposite side.
The second car was in the process of attempting to retrieve the stranded car, by means of some bunnings rope tied around the tow bar and leading to the waters edge. As i pulled up, they were just about to go into the water to attach it to the stranded car. Mind you, this water was running fast enough that the 7 or 8 ft journey from edge of the water to back of the car (the water was over the bridge on both ends and creeping up the steep hill) went from ankle deep to thigh deep and was strong enough they had to start on the upstream side of the bridge as it pushed them down toward the car.
I politely called a halt to the proceedings at that point, diplomatically refraining from pointing out that one of them was probably about to get killed. Explaining the mechanics of the impending accident only took about a minute, and you could almost see the blood drain out of their faces when they realized what was about to happen. The plan they had cooked up involved the driver of the stranded car actually getting back into the vehicle and 'steering' it out while the other guy pulled it out with the rope.
I volunteered the use of my winch instead, and after explaining why it could not just be hooked onto the towbar of the stranded car, we managed to find a solid hook on the chassis after feeling around under water up to our shoulders. Luckily i had a pair of boardshorts in the car as i didnt fancy doing this in my work clothes ;)
Cutting it short, we successfully winched the unoccupied car out, although the downstream side did rub against the edging at one point and scratch up his front spoiler, he was ok with just getting the car out of the water. Tow truck was called and i bid the pair farewell, retracing my steps to find a different route to work, as even i wasn't game to tackle the water flowing across the slippery narrow bridge.
I still shudder to think what might have happened if i hadn't turned up. Everything they were doing was logical to them. Towbars were heavy duty models, rated to 2500kg. Rope definitely wasnt, but it was the only thing they had and they had doubled it twice to spread the load. Not sure about the getting back in the car, maybe they had some idea of guiding it backwards. But the whole thing added together was a recipe for disaster. Quite a few cars have floated over the side or round the edge of that bridge. The drop from bridge to creek bottom is about 6 feet, more than enought to swallow a car.
Part of the problem i think was that watching the videos and so forth on youtube of recoveries by 4WD, it rarely mentions the use of proper equipment. In most, the distance tends to make snatch straps look like rope, and since most recovery points are mounted towards the centre and near the towbars, it almost looks like the towbar is used to recover. I cant blame these guys for trying to get their car out but how many deaths occur because people emulate stuff that we do, albeit without the knowledge.
Not saying these guys need to get training courses, neither was a 4WD or even a AWD, i doubt they will ever be in that situation again and it was only happenstance they had a rope to make the attempt possible, but still..................
Jeep_jk112
Great work zuki!
I would even go as far to say they would be in the news tonight, if you had not shown up.....
prawns
Teaching correct/safe recovery techniques to a "2wder" who generally believes they wont ever need it hence have no interest in learning would be a exersise in futility I think (especially when most 2wd vehicles dont have the correct equipment installed to effect even a basic snatch strap recovery for example)
I agree however - it makes damn good sense to try and get at least some of the basic techniques out there and what is safe and unsafe. I would love to see a youtube montage of towballs shooting off like cannonballs for instance, reckon somthing like that would grab a 2wders attention (cause while watching it I bet they will be thinking, "Crikey thats what I would of done")
I didnt have a 4wd a couple of years ago - and to be honest it would of made sense to me to use the towball as a recovery hook as well - Ignorance is not always bliss (especially if it ends in a emergency ward or worse)
Some people just dont seem to care though - Ive got video of guys snatching off the towbar in highly modified 4wds which had recovery hooks, but they chose not to use them due laziness and a mud sufrace they didnt want to kneel in. My mate went over and warned them and only got a "she'll be right" response.
Well, I guess "she'll be right" right up to the point where it isnt and somebodys head is caved in by a towball cannon (which was my response to those 4wders lols)
Good on you mate for helping out and educating those guys - hopefully they pass the knowledge on - You may of even saved a life theres already been a death from these floods, and that was in a proper 4wd let alone a 2wd that was not made considering those conditions
Zukiman
Well, i won't claim to be a HERO......:D
Nah, just common decency and not wanting to have it end up on the news. Hope to think that someone would do the same for me in the circumstances.
Mainly the whole common sense thing, if they stepped back and took a really good look at what they were trying to do, i doubt they would have attempted it. Don'y need training, just basic understanding that cars weigh a friggin lot, water weighs even more and that towbars are for towing only. Problem is that when is says 'Rated to 2500kg' on the little sticker, people easily misintepret it's capability.
Annoying thing is, had the camera in the passenger seat, the video on the dash and the iphone in the pocket and didn't even think to take a single picture......:eek:
80lover96gxl
Great work Zuklman, had you not showed up when you did the result more than likely would have been disasterous.
Education on using tow balls for vehicle recovery should be part of any driver training program,eapecially teenagers doing driving tests,my son attended a simulated road accident course at school recently and this would be a perfect oppertunity to explain the dangers of such an exercise.
Unfortunitly the she'll be right attitude gets thrown around alittle to loosly and comon sence gets thrown out the window,especially in situations where someone is stuck,adrenilin is pumping and the prospect of loosing a vehicle is iminent there first priority is recovering the vehicle instead of safety,which happens all to often.
Your intervention in this morning's little situatoin may well have made it possible for the said potential victoms to go home this evening to there families.
I applaued your actions this morning,good onya mate.
cheers,
Brian.
03hilux
Its good to see someone willing to lend a hand rather than get the camera out. You did the right thing by helping them and i dare say most people would have done a u- turn after seeing the bridge blocked by a car and taking some happy snaps to show heir mates. Yes photos would have been good, but the time it takes to get a photo, thing can go pear shaped.
Well done. I hope the guys shout you a beer for your efforts.
croozza
I would have got the camera out....lol There's heaps of money to be made on Funniest Home Videos...
prawns
But if it had turned fatal - could you live with yourself knowing that you deliberatly withheld informed advice/help in favour of possibly winning some cash on tv? Especially if it turns out that they left a young family behind
Besides, funniest home videos wont show fatal accidents so its in your best interest everybody survives :D
I woulda made one of them film the recovery :)
Great stuff mate,Dont you feel great within yourself youve helped out someone and averted something that could have gone to custard...:D:D;)
The winches are a fantastic bit of kit,plus you gave it a run also....
Zukiman
Managed to get a photo of the flood yesterday afternoon. I thought the water would have gone down by now, but if anything it is bigger.
Google Street View of normal bridge (this is the side i winched from)
Photo of the flooding (opposite side, the place i winched from is almost underwater now)
You can see the wooden fence in the top left of the first photo, it is above the level of the barrier on the bridge. This is the fence that is almost completely submerged in the left side of the second photo, giving you an idea of just how deep that water can get. Got some video as well, that water is moving at a fair clip, enough to generate some white water as it hits larger obstacles.........
monk2
no one hurt no property lost but it could have been a hole lot different, not wanting to condem the people that where trying to help the stranded moterist but they needed to look a bit closer at what they where doing, userly you get onlookers and no help but at lest they were going to try, nice to know there are some out there that still lend a hand well done Zukiman
deepop
Well done Zuk - glad to see some people willing to help others at their own risk!
That's the nice part of the post - now I have to play devil's advocate.
I wasn't there and I probably don't know the situation completely but I need to point out - what would have happened if that car went over the bridge whilst it was solidly attached to your car by the winch cable. Best result would be that you were able to unspool your cable completely and let it break off the drum at the end - worst is you get dragged in with the other car. If you wouldn't let the other driver sit in the car then you knew there was a risk of it going off the bridge. And what about if this knob jockey chases you up now and makes a claim on you about the damage to his car - we all know it could happen.
Sorry but I have to suggest another option for this situation. Leave the car there to its own devices (he drove it in there after all), take the bloke back home and wait for the floods to subside before recovering it.
Don't attack! There are a lot of people reading this forum (probably a few very inexperienced) who should be applauding you willingness to help but also need to be aware of the dangers of this situation.
croozza
I joke because nobody got hurt...... You dont think I am a sadest do you????
prawns
I was umming and arring about the meaning of your post as I dont know you well enough to figure if you were serious or not lols - Decided to post anyway incase others reading did actually feel that way for real - All good mate :)
Zukiman
I wasn't there and I probably don't know the situation completely but I need to point out - what would have happened if that car went over the bridge whilst it was solidly attached to your car by the winch cable. Best result would be that you were able to unspool your cable completely and let it break off the drum at the end - worst is you get dragged in with the other car..
Actually, its a good question but i had already condiered it before winching it out. At most, if the car went over the barrier, it would have dropped about 4-6ft and maybe moved laterally about 4 ft, before wedging up against the trees beside the bridge. And i was far enough back that even had it dragged my car when it did so, it would not have gotten mine into the water. And the wireless winch controller is very responsive, if it started to go i would have been on the 'out' button right quick.
I didn't want the other driver in the car when they were trying their recovery method, as it seemed highly likely their way would fail. When i was recovering, i simply didnt want anyone in the car for two reasons, one that it may flood the interior when dragged out against the current, and two i didnt want them attempting any maneuvres that would dislodge the vehicle from its position. Turning the wheels may have allowed the car to roll over the edging for instance....
As for claims, we never actually introduced ourselves. Shook hands at the end but never got a name of either fella. And unless they can recall my numberplate it would be hard for them to remember me as i never introduced myself either. Also, no footage or photgraphs, especially as my car had several devices for doing so, would make it seem highly suspicious should they try to take me to court. Their word against mine. That is, unless they find this forum!!! :D
deepop
Thanks for clearing that up mate. Also appreciate no rant - I wasn't trying to start a blue, just having a say.
With the style of your reply you make me think that we might enjoy sharing some beverages around some burning wood whilst char grilling the edible remains of some beast.
We will do that when we get a chance!
Zukiman
I have been known to partake of a beerverage or two, especially whilst indulging the inner pyro. And if the char-grilled beastie was hopping or flying around some hours previously before contracting a fatal dose of high velocity lead, all the better............
We are planning a southern trip for end of the year/beginning of next. May have to time it to coincide with the Mexican Meetup you fellas have.
deepop
Yeah mate, come on down.
Talbotville's a great place and a fantastic base for doing a lot of the high country.
