strange noices under torque...
hey @ all...
i spotted a kind of strange noises under my pajero NL...:mad:
its only up uphill and under a certain amount of torque... it's a kind of a very bright ratteling - or i would compare it wit a liquid under pressure - running through a pipe with air bubbles in... its either in 2wd 4wd and 4wd low range...
i get a kind of worried...
is someone here with a similar experience?
or is there someone who got an idea?
any help is highly appreciated...
cheers
Tom
teza h
Is it an auto trans,cos thats the only thing i can think of that would make that kinde of sound.
Grumpy
If it's an auto maybe trans need attention but if it's a manual maybe thrust bearing on clutch may be on it's way out.
Jarh73
Are you sure its not knocking or pinging? (pre ignition)
Has anyone touched the timing or engine recently?
Bad batch of fuel maybe too?
Justin
croozza
it is going to be hard for anyone here to give you an idea of what the problem is, it is best to see mitsubishi about it, they may be able to hook it up to a machine and it will tell them if anything is wrong
bmurray2250
Something to consider is to record the sound. Most mobile phones have a voice record function, the only thing is to get someone to drive the 4by and you find the area the sound is strongest then record it. This will help to point at the area the noise is coming from and give the mechanic some idea what it could be.
