Straight from the Horses mouth
03hilux
I posted the below in the Technical threads, But in case some dont read that far down the Forum I'll put it here aswell.
To add to the hitch pin debate, i emailed Hayman Reece regarding the pin and its load rating. Below is a copy of the email they replied with. You may notice that there are NO numbers (ratings) given by them.
"Hello Roger,
Thank you for your enquiry regarding the use of the towbar on your Hilux. The pull pin has a shear rating of well and truly above the rating of the towbar but to align with the Australian Standard and Australian Design rule our towbars are designed and tested for towing purposes only, we do not test for the types of forces that can be experienced in situations like recovery of a vehicle that is bogged.
If in the unlikely event of a failure when being used for recovery purposes the failure may not be covered under warranty.
I hope this information has been useful to you and if I can assist you any further please feel free to contact me.
Gary Gardiner
Towing Technical Support Rep. QLD "
So there you have it. Its basically a "use at own risk" answer.
Lost 2
Thats called covering your ass,not the horse pulling it.
In fairness they are only designed to tow,so legally no claim!
Just between you and me,the pin does do its job/recovery wise.
