blackout
I am currently in the process in obtaining my Pressure Vessel Inspectors ticket through the Australian Institute for the Certification of Inspection personnel.
We were briefed by a Senior rep for the Governing Body of Work Health Safety on Pressure Vessels. We were presented incidents that have occurred throughout Aus and Overseas and I had to witness some fairly intimidating and graphic photo's of what happens if a human body get's in the way of a ruptured pressurised vessel.
Now this rep has the authority to rock up to any workplace and shut down an entire company if any type of vessel containing a fluid or gas is not complying to legislation. Owners of a vessel are required to have a certified inspector check internally and externally and is free of defects. The hazard class of that vessel determines the frequency of inspection, just like your BBQ bottles need to be checked.
Now he has no control on what the general public get up to but he specifically raised the issue with 4x4 owners fabricating up ways of storing large volumes of compressed air, and he knows exactly how people are doing it, Sliders, Chassis Rails, Fire Extinguishes, old Scuba bottles, old gas bottles and so on.
This is a big no no.
Do not make your own pressure vessel.
You are putting not only yourself at risk but others within a large vicinity when you start compressing air into a material that has not been design engineered to handle it. It's not only the stresses on the material you have worry about it's the corrosion that happens internally over time and you have no idea on how bad it is until it' too late. It's also the fittings you could be using are not rated or are corroding. I saw the end result of what was a fitting that housed a thermometer on the side of a manifold, it let go due to galvanic corrosion weakening the thread, it pierced a guys thigh, severed the aorta and he later died to to blood loss.
If your home made vessel was to rupture and someone is either injured or even killed you could face a conviction against you for negligence or worse.
Until today I thought it was a great idea to store compressed air in your fourby, but these graphic incidents really shook me up on what could happen, even with the smallest of vessels at the lowest of pressures the injuries are horrific if you are in the way of a rupture!
Don't take the risk, have a beer while your compressors filling your tyres or blowing ya mattress up. What's the rush!
