Storage in a ute
Lovey
G'day all,
I'm looking to acquire some recovery gear and I'm in need of for some storage ideas for inside the tray of my Colorado, and I was looking for some inspiration. I don't want drawers installed, as I want something that can be removable.
At this stage the only idea I could come up with is a space case to put between the wheel arches. I know this could be a bit limiting when I'm trying to access the recovery gear if it's at the front of the tray, but at least it's removable.
I also looked at a pair of 'Undercover Swingcases' which use up the space behind and over the wheel arches, but I've ruled that out at the moment due to the crap exchange rate with the US. There are other similar style cases to these, however I haven't managed to find anyone that sells them in Australia. With this in mind though, has anybody used an under body tray inside the tray, maybe with the angled portion over the wheel arch?
If anyone has any ideas, please feel free to let me know and some pics would be great too?
Thanks for looking.
Gavo
Back when I had a dual cab. I whipped up a super basic false floor, that comfortably fitted 4x heavy duty black tubs.
Worked beautifully for me. Had camp tubs, recovery tubs, dive gear tubs, food tubs, tool tubs.
Essentially I had a bunch of tubs in shed, slid what I needed into spaces as required.
And being a simple false floor design, I could easily lift it out and have full size storage.
Now I've just realised I had a canopy. You probably don't!
Hahaha maybe the space case box is a good idea.
Lovey
G'day and thanks Gavo,
I do have a canopy, I just need to get it better organised when I travel instead of just throwing everything in there and hoping for the best ;-)
Do you happen to have any pics or maybe a diagram of what your set up was? I've heard of people doing a 'false floor' in their utes, but I'm having trouble visualising it, and my googling skills are letting me down too.
Thanks again.
ULost2
how much gear are you getting ..... like what ? might pay to get it first then see how well it packs into ??????
You said you have a canopy I expect it's a fibreglass one maybe you could make a shelf that hangs from the roof or is attached to the sides to store recovery gear just the light stuff like snatch straps etc which would be easily accessed when opening the tailgate or one of the side windows. Something along the lines of shelving but changed to suit your needs http://www.rxi.com.au/ute-shelving-Australia
Maybe even a hanging storage net.
Storage drawers create that false shelf and allow easy access to the area underneath, usually via 2 drawers.
You lose some area, the walls / drawer slide thicknesses etc, but area to carry is greatly increased.
You need to keep in mind the weight thing, be able to carry more usually means you packk / end up carrying more, much more than is really needed.
Try and load heavier items up front of the drawers / other storage, especially in dual cab tubs / trays.
Off road the stresses on the chassis are greatly increased, always a good idea to pack as far forward in a tub as possible, and keep under GVM when loaded for a trip.
You can do a false ply floor over the wheel arches and then just slide plastic tubs under it
I use to put a strap/ rope on the first one that goes in up against the headboard so that you out can just pull it out by the rope
Lovey
I'd be looking at the usual things, snatch strap, tree trunk strap, etc, a drag chain, shackles which I can keep in a bag. I've also got a collapsible shovel, air compressor, jumper leads and some hand tools. I'd also be looking at moving the standard jack and associated bits and pieces from the spot under the rear seat, as I've got child seats and it's a bit painful to get them out now.
I put mine under the seat it's easy to reach
I don't know if I'd have enough room under the seats, damn modern cars.
Thanks Batts,
it is fibreglass canopy and I like the idea of using the 'dead space' at the top of the canopy.
You need to keep in mind the weight thing, be able to carry more usually means you pack / end up carrying more, much more than is really needed.
Thanks Les,
That's one of the reasons that I was shying away from a drawer set up, as I just know that I'd end up filling them up ;-)
Thanks for the tip re keeping the loads forward in the tub, I'd hate to end up with a Coloradonana.
Thanks Alby,
Do you mean a false floor that covers the entire tray, or just the portion over the wheel arches?
Thanks again all for your replies, it's given me some food for thought.
Thanks Alby,
You could do either, depends how much room you are wanting to make. A standard sheet of ply is 1200 wide so you could just do 1200 deep and either cut hatch lids into it or slide tubs under it. All depends on what suits you
ULost2
there would be spare space on the floor between the front-back seats for something (??). May not be the place for heavy/rattly gear if it can't be anchored down properly.
"drag chain": what are people using those for? I can only guess for dragging firewood. If so; consider a shorter length to go around the wood and then use a rope/strap/cable from chain to vehicle. That would save a fair bit of space and weight; the shorter chain could be stored outside somewhere ..... tow/roo bar ???
"tree trunk strap": I presume you have a winch then
" moving the standard jack" . A bottle jack can be handy when things go a bit wrong however the usual standard jacks go down lower and are lighter. all this stuff really depends on how ready you need or have to be for something going wrong
It's a bugga high lift jacks are so damn heavy; and big. Then we also need the wheel straps/hooks ........ and a base block. I have never used my HLJ which is good as it's a sticky bitch of a thing, but the day I don't have it will be the day I need it
ULost2
what would you use to raise it? would it need be anchored to the tray?
Once you create a floor you can then bolt down stuff above it using the dead space,I have drawers and cannot believe the amount of dead space I use that I couldn't beforehand..
hiluxdriver
I'd look to move the hard stuff (compressor, shovel,chain) to a nice safe place in the cabin and chuck the rest in a canvas bag in the back. The bag is fine to slide around in the back and won't damage anything it hits. A space case needs to be tied down and as you say may not be the easiest to reach when you need it. But then again recovery gear doesn't get used every trip so a set and forget space case may be the way to go. 6 of one, half a dozen of the other I suppose.
Chatty
Back in the day considered an essential (but heavy) part of any recovery kit...
In SES we always carried them as it didn't matter what you were trying to tow/drag across whatever - the chain was pretty well indestructible. Fabric slings/snatch straps/extension straps don't cope well when dragged across or are rubbing on rock - even wire rope on a winch doesn't really like conditions like that.
Drag chains used to give us the option of using chain where damage was likely and keeping the wire rope and fabric slings to spots where damage was less likely.
Chatty
Now, back on topic - if you're going to use plastic tubs get the heavy duty ones from a plastics store like Menzels here in Adelaide - don't use the cheap ones you can buy everywhere - they break soooooooo easily. The extra few bucks is money well spent.
Lovey
Thanks for everyone's suggestions, they're very appreciated.
What would be the safest/best way to secure the false floor to the tub?
Thanks again.
